04-04-2009, 09:24 PM | #1 |
profeshinaly unimployed
drivers side door
this door is screwy its hard as heck to shut and the window is real hard to roll up and down the passenger side is easy on both of those things but i tried spraying lube in the door and still nothing so how can i fix these too problems
hard to roll up/down window hard to shut door
"having mud flaps is like asking for a smaller trophy" |
04-04-2009, 09:36 PM | #2 |
6.0 powered square
Re: drivers side door
for the window I would start with adjustment, if its still doing the same thing, it might be worn out
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
04-05-2009, 11:18 AM | #3 |
Robert Olson Transport
alot of the time on the widows the material in the tracks comes apart and acts like a stopper.. take the door panel off and clean them. then use a water based lube and see what ya have.. as to the shutting see if the door wiggles up an down in the open position you may need bushings and hinge pins..
lube the beck outta the lock with white grease lastly is the striker and the lock alligned properly?
04-05-2009, 01:49 PM | #4 | |
Hinge pins and bushings....The door has probably drooped some or a lot It is very common for this to affect the alignment of the striker pin, causing hard shutting/bouncing back open. Sometimes the previous owner will have adjusted the hinge to make up for this, but it does not cure the real problem, so it comes back.
The window could be as simple as lack of lubrication, worn guides, or even misaligned guides due to "slamming" the door that won't shut.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. |
04-06-2009, 04:46 AM | #5 |
Weatherstripping can also cause the door not to shut easily. If you remove it and the door shuts easily, either replace it or cut off the portions that are hitting the door wrong. The window difficulty can be caused by dirty tracks or the guide tracks coming apart in the door where the window goes up and down. I just fixed my driver's window by taking the door panels off and lubricating the window crank gears, the roller tracks and rollers with white lubriplate. You can see these rollers (4) when you roll the window down into the door. I'm just starting here in this web site. You are very prolific with almost 500 posts. I've got issues with my '85 C-10, and am getting good ideas from this forum, hope you are too.
04-06-2009, 10:43 PM | #6 | |
Any one know where I can find a hinge pin rebuild kit for a 71 K10?
"I'll Procrastinate Tomorrow" quote by LEEVON 71 K10 long fleet (sons truck) new 370hp 355, sm465 np205, 3.73's 33's 70 K20 long fleet 98 G3500 work van |
