GM ONLY BABY!!!
Need pics of rear bag mounting.
I have searched rear bag mounting pics and haven't found what I need. I need to cut down the long steel tube that I got from Suicide Doors. I have the upper and lower plates. I have RE 7's on my 72 GMC LWB that I am putting on a 71 Chevy frame. I also have the C notch installed and the 2" drop blocks. What do I need to do to mount the bags to the frame and trailing arm?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
Re: Need pics of rear bag mounting.
Here's mine before I painted it last week.
Project 61 build thread Some people spend an entire lifetime wondering if they've made a difference....The Marines don't have that problem. Sic vis pacem, para bellum. -- "If you want peace, prepare for war." |
SOLD
Location: Poorest state in America(Breaux Bridge,Louisiana)
not sure if this helps or not.....
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 |
GM ONLY BABY!!!
Thanks Prostreet- So I see that the cups go on top. I purchased my kit about 2 years ago, so I'm kinda lost. I called Suicide Doors after I received it and do remember them saying that I would have to cut the 6" dia. steel pipe that I got from them. But how do I know hwo tall that it needs to be for the upper cup. I guess I need to weld it to the plate then? I know that I need to keep enough space for the air fitting on top too, right? Can I run the air fitting an line thru the frame at the top of the bag? I recall seeing a thread on here a while ago with some good setup pics, but can't seem to find it now.
67-72 parts collector,…
![]() Join Date: Nov 2002
Just bolt the bag to the frame and trailing arm. No brackets required.
Drill a hole in the frame for the air line fitting to fit thru. You will need to drill 2 mounting holes in the frame also. Use a 3/8"x4" bolt to mount the bag to the trailing arm.
GM ONLY BABY!!!
Lolife- I guess you used a big flat washer to for the 3/8 bolt that goes up thru the trailing arm to the bag, correct? I'm runnin 1/2" line, so that's going to be a huge hole thru the frame for the line fitting. Damn, my frame and trailing arms just got powdercoated, so now I have to drill holes thru them? Oh well, I had to drill holes for my drop hitch to mount to the frame. Anyone got pics of the upper bag mounting look from inside the frame rail?
Knuckle head
The hole isn't that bad. I did it on my truck, the hardest part is getting the air line pushed into the fitting.
Adam '71 SWB/Step ![]() 2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC '00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed '09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD) 1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785 1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis. ![]() |
GM ONLY BABY!!!
Ajohn- funny, I just replied to yours and you just replied to mine. I Glocks rear disc conversion on my 72, and was using a disc/drum prop. valve with no problems. I now have the disc/disc valve, but I havent' noticed any difference. Sounds to me like pushrod length. I had to modify the rod in my 66 Chevelle too.
chevydog66,... yes, use a big washer. I use an extra thick one. I made a template of the upper bag holes and then transfered that to the frame. I also put a loop in the airline,... so I can connect the airline to the fitting and then mount the bag.
(This will help down the road,... if you ever have to remove the bag)
GM ONLY BABY!!!
Put a loop in the airline????? What size u runnin?
GM ONLY BABY!!!
66 Prostreet- how did you attach the upper cup to the frame? Should I run a 90* line fitting then?
Sorry,... I just realized you said 1/2" line. I have 1/4". No need for speed on my beater.
#13 |
GM ONLY BABY!!!
Found some. Now I would like to see pics from the inside of the frame rail.http://www.67-72chevytrucks.com/vboa...t=rear+install Looks like I will be drilling some big holes.
#14 | |
SOLD
i used the ART rear coolride kit in the back. it uses the existing holes, with a 90* fitting. the threaded rod goes through the factory hole
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 Last edited by 66chevy PROSTREET; 04-05-2009 at 05:36 PM. |
#15 |
Active Member
Kevin 72 Chevelle 67 C10...454/TH400 Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=193961 |
#16 |
GM ONLY BABY!!!
kevncar- ya I seen that, but I'm not seeing what kind of fitting to use at the upper rear bag. It appears to me that there wont be much room for me to tighten up the 1/2" air line fitting into the bag, and tighten up the line once I get it onto the bag, due to the frame and upper shock crossmember.
#17 |
Knuckle head
I used the 90* swivel fitting. Its the one you push the tube into and it locks itself in. No tightening of compression nuts required. Its a real pain in the butt getting it in all the way.
#18 |
GM ONLY BABY!!!
Yep, got em in, but I had to add a coupler to make it set up a little higher in the frame rail.
