Old 04-04-2009, 09:52 PM   #1
jwa76fleetside
jwa76fleetside's Avatar
need help please
i am in the midst of putting in my lowering kit when the shop called and said one of the plates were broken on my drivers side rear leaf springs. He said i must have a heavy duty kit on there because i have 8 plates per lear spring (instead of 4). Is this normal on a 76 fleetside? should i try to find an 8 plate leaf spring to replace the broken one on monday and should i just pull both sides out and replace them both with 4 plate leafs? thanks
Justin
76 Chevy Fleetside
63 Lincoln Continental w/ Ford Racing 460 (550hp)
2012 VW GTI
2013 Escalade
2008 Harley
jwa76fleetside is offline   Reply With Quote
Old 04-04-2009, 11:02 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: need help please
as along has the 4 leafs are the same length has the 8 leafs 52 and 56 are the different lengths
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-04-2009, 11:06 PM   #3
flamingbig10
6.0 powered square
also if the 3 longest leafs aren't broken then the other 5 can be removed, which will lower it about a 1" or 2" more and a softer ride
Aaron
Old 04-04-2009, 11:14 PM   #4
jwa76fleetside
what are 52 and 56? the lengths of the leafs?
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 04-04-2009, 11:16 PM   #5
flamingbig10
6.0 powered square
yes
Aaron
Old 04-04-2009, 11:33 PM   #6
jwa76fleetside
i am putting on a flip kit (6" drop) Can i still remove the other 5 leafs and just leave the 3 long ones?
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 04-04-2009, 11:34 PM   #7
flamingbig10
6.0 powered square
yes that's what I have
Aaron
Old 04-04-2009, 11:39 PM   #8
flamingbig10
6.0 powered square
Aaron
Old 04-04-2009, 11:50 PM   #9
jwa76fleetside
awesome. thanks
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 04-04-2009, 11:51 PM   #10
jwa76fleetside
if it is one of the 3 long ones that broke though I will need to just replace both sides with 4 plate leafs or find another 8 plate and then remove 5 plates from each? which would make more sense?
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 04-05-2009, 12:00 AM   #11
flamingbig10
6.0 powered square
no problem oh it doesn't matter I would go with both of the 4 leafs, because the other 8 leaf pack maybe weaker or stronger, than yours, and might make the chevy lean even more noticeable
Aaron
Old 04-05-2009, 12:04 AM   #12
jwa76fleetside
alright. appreciate the advice. I will keep my fingers crossed that it wasnt one of the long ones that broke. they said the 2nd leaf? Im hoping i can just remove the 5 shorties from both sides and save some $$$. haha.
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 04-05-2009, 12:21 AM   #13
flamingbig10
6.0 powered square
I'm glad i was able to help
Aaron
Old 04-05-2009, 02:02 AM   #14
enaberif
http://www.generalspringkc.com/index...parent=45&pg=1
enaberif is offline   Reply With Quote
Old 04-05-2009, 02:04 AM   #15
enaberif
Ok the not able to edit our own posts.. is really going to get tiring.
That link will allow you to see the differences in spring setups for our trucks that were stock.
Old 04-06-2009, 09:48 AM   #16
jwa76fleetside
thanks that helps out. So if I have 56's (8 leaf on the back) am I stuck (without modification) with those because the 4 leafs state they are 52's.
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 04-06-2009, 04:06 PM   #17
enaberif
Good question because I'm in the same boat as you!
Old 04-06-2009, 04:21 PM   #18
jwa76fleetside
ok i just ended up taking out the broken leaf and running with 7 on both sides. taking anymore out caused the ass to drag. Looks pretty good now. I will post pics once my rims are on later this week.
76 Chevy Fleetside
2012 VW GTI
2013 Escalade
2008 Harley
Old 04-06-2009, 04:46 PM   #19
flamingbig10
6.0 powered square
It must of been the over load spring the short thick one at the bottom of the leaf spring pack
Aaron
