Old 04-04-2009, 11:26 PM   #1
myfirstcarwasa73trk
myfirstcarwasa73trk's Avatar
finaly took down to frame in front
more pics soon
myfirstcarwasa73trk is offline   Reply With Quote
Old 04-04-2009, 11:32 PM   #2
myfirstcarwasa73trk
Re: finaly took down to frame in front
What all can I use off my 85 on 67 to cheep down rebuild 85 was my every day driver all good
Old 04-05-2009, 12:59 PM   #3
Skirkpat
Skirkpat's Avatar
You can use the Front suspension/disc brakes setup (will need new ball joints I think) engine/trans......driveshaft if they are both shortbeds...power brake booster with a little modification, power steering box, I think...
Skirkpat is offline   Reply With Quote
Old 04-05-2009, 02:14 PM   #4
myfirstcarwasa73trk
now with that how exactly do I modify the booster to fit I have the motor and trans for sure is what I am taking 350/350 comdo motor mts and mount brackets and the trans x member will need to be used was three on the tree straight 6
Old 04-05-2009, 02:17 PM   #5
myfirstcarwasa73trk
pics
Old 04-05-2009, 02:27 PM   #6
myfirstcarwasa73trk
67 front suspention is it worth it to put on GM puals front disc brake kit or go with my 85 front k member and brakes torn because I want power brakes and steering but not sure witch way to go about getting it will through pics of doner 85 in a day
Old 04-05-2009, 04:14 PM   #7
Skirkpat
Skirkpat's Avatar
Keep the engine stands (missing in pics) that bolt to the frame, and moter mounts, those are all you need to put your 350 in,
To use the Auto trans you are going to have to cut out the Manual trans cross member that your bell housing bolted to. And use the one from the 85 that mounts in the back, you will probably need to drill holes in the frame to bolt it to.
Everyting can stay up front as far as suspension, but you will need new 73 and up ball joints, and possibly tie rod ends..then use your 85 spindles and brake components,
to use your booster you will need to lengthen the rod from your brake pedal to the booster (using a threaded coupler and extra threaded rod from hardware store)
your power steering box will work, but you will need an adapter kit, 67's did not have the dimple where the box bolts to the frame tht allows it to lay flush.
Old 04-05-2009, 06:19 PM   #8
myfirstcarwasa73trk
as far as the proportion valve use the one from the 85?
Old 04-05-2009, 06:55 PM   #9
Skirkpat
Skirkpat's Avatar
yes, they are different for disc/drum setup.
use the search feature up above, not the google one, the one above that...alot of good info here, just gotta search it out? The reson I know a little about what you are asking is that i asked the same questions a few months ago !!
Old 05-09-2009, 01:51 PM   #10
myfirstcarwasa73trk
got my new k member in place just noticed a new problem need your help! My steering from my 67 is smaller than the 79 I just put in how do I solve this problem on the cheap? and I do still have 85 doner that is my every day driver can I steel the steering, including power steering? Got a good idea it will wok just want conformation
Old 05-09-2009, 01:52 PM   #11
myfirstcarwasa73trk
old
Old 05-09-2009, 02:07 PM   #12
myfirstcarwasa73trk
new
Old 05-10-2009, 09:27 PM   #13
myfirstcarwasa73trk
Here is my problem maby this will help moog part ES2020RL
Old 05-11-2009, 09:19 AM   #14
ZombieWeinerDog
ZombieWeinerDog's Avatar
deja vu
1972 longbed- 454
1967 shortbed- 355
ZombieWeinerDog is offline   Reply With Quote
Old 06-10-2009, 12:06 AM   #15
myfirstcarwasa73trk
Finaly got the three on the tree cross member removed after my cusin came over to lift the cab while I grinded of factory rivets and I just used a 5 foot pry bar to brake it free from frame man these are some tough frames yeah! Also got her back on tires of jack stands yeah. But that led to problemo not enough shims on upper A arm on driver side and sits little funny? Think I will tow it to alignment shop instead of driving? to tired to go take new pics so here have few old ones you aint seen. lol
Old 04-12-2010, 10:49 PM   #16
myfirstcarwasa73trk
time to put up some more pics
Old 04-12-2010, 10:52 PM   #17
myfirstcarwasa73trk
some more and of the doner 85 my new old rear end
Old 04-12-2010, 10:59 PM   #18
myfirstcarwasa73trk
some progress thanks too rusty and texas firefighter and my buddy brad and to you folks on here!
Its harder than it looks and three times expensive! lol but worth every trip to the ER at 2 in the morn lol, thanks hunny.
Old 04-12-2010, 11:11 PM   #19
myfirstcarwasa73trk
little more
Old 04-12-2010, 11:14 PM   #20
myfirstcarwasa73trk
few
more
Old 04-12-2010, 11:17 PM   #21
myfirstcarwasa73trk
drive shaft
Old 04-12-2010, 11:26 PM   #22
myfirstcarwasa73trk
almost on the road can use some help got to get her legal now need Idea for brake light swith cheap
Old 06-04-2010, 10:50 PM   #23
myfirstcarwasa73trk
took for first test drive around the block w/ only front brakes
(speed way sent wrong e-brake cables)
need new steering box too!
Old 06-04-2010, 11:42 PM   #24
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
one great lookin' 67 your missing the chevy emblem in the grille! you got some great patina goin..get your wheels all matching and roll it!
John
1999 Toyota Tacoma 4x4
Old 06-05-2010, 12:58 AM   #25
chevyblazer
chevyblazer's Avatar
awesome hope y take out my truck soon just to give it a ride
cucharitas customs
chevyblazer is offline   Reply With Quote
