Old 04-05-2009, 08:42 AM   #1
70GMCer
70GMCer's Avatar
What Size Wheels Fit?
May have been asked before.....But, what newer factory wheels fit our 1970 & earlier 6 lug bolt pattern, & would have the correct offset for disk brakes? I think Toyota & I think Nissan do. What others??
I would like to stay at 15 inch. What newer 15X8 steel wheels would fit?
Going to be scouting local junk yards and would like to see what's available.
Maybe someone could get a list together & place it in the FAQ....
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 04-05-2009, 12:02 PM   #2
BossHogg69
motor exploder
BossHogg69's Avatar
Re: What Size Wheels Fit?
88-98 chevy half ton 4x4 wheels will fit, and any of the 99-present half ton wheels fit, though all these wheels will be 16" or bigger. Just make sure to get the right lug nuts, since your wheel studs are a different size that the late model trucks. hth...
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 04-05-2009, 12:43 PM   #3
70GMCer
70GMCer's Avatar
Thanks for the reply. I guess I'm needing to know what other truck makers other than GM will fit.
1997 GMC Sierra Ext
1965 Mustang
Old 04-05-2009, 05:52 PM   #4
70c10
67-72 Addict!
70c10's Avatar
Steve, I know you are looking for used but here is a Summit list of all 15" rims with the 6x5.5" bolt pattern.
http://store.summitracing.com/egnsea...115+4294793325
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 04-05-2009, 06:22 PM   #5
70GMCer
70GMCer's Avatar
Thanks Jim, saw them before. Just trying to find out what other factory rims are out there.
1997 GMC Sierra Ext
1965 Mustang
Old 04-05-2009, 08:23 PM   #6
70c10
67-72 Addict!
70c10's Avatar
I found this with a list of different makes and models. Just look for the 6x5.5
http://www.sporttruckspecialty.com/b...mccadillac.htm
Jim
Old 04-05-2009, 08:33 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
odds are, none of them will look right. The back spacing is all out of whack and they would be tucked in too far.
Old 04-05-2009, 08:41 PM   #8
The Nippons have the same pattern and so do Jeep products.Those are the only factory ones.None will be 8" except for GM rallyes and Jeep had some.Are you looking for anything other than GM rallyes?Cuz,I have a set I`d sell reasonable if those will do.
Old 04-06-2009, 06:55 AM   #9
70GMCer
70GMCer's Avatar
I was just wondering as I mentioned earlier. I will be making junk yard runs and wanted to know what would fit in case I see something to my liking. Right now I have 8" truck rallies.
1997 GMC Sierra Ext
1965 Mustang
Old 04-06-2009, 06:57 AM   #10
70GMCer
70GMCer's Avatar
Neat site....will be bookmarking that one. thanks jim
1997 GMC Sierra Ext
1965 Mustang
