Old 04-05-2009, 09:35 AM   #1
pete29
Gas gauge help
I recently got my gas guage hooked up in my 72 chevy stock tank behind the seat. When i turn the key it always goes up to about 3/4 tank and stays there, even when its basically empty. What could be the problem?
pete29 is offline   Reply With Quote
Old 04-05-2009, 10:18 AM   #2
72armyswbtruck
72armyswbtruck's Avatar
Re: Gas gauge help
Might be a stuck float in the tank.
"Remember, They can Kill You, but they can't eat You, That's against the law!!!!!!!!!"
72armyswbtruck is offline   Reply With Quote
Old 04-05-2009, 10:27 AM   #3
pete29
Re: Gas gauge help
Whats the best way to get it unstuck
Old 04-05-2009, 02:23 PM   #4
eightbanger
454 MAKES IT ROAR
eightbanger's Avatar
Re: Gas gauge help
You will have to remove the float from the tank to see if it's the prob, but it could also be the resistor prob these are found on the back of your gauge, also check the Brown earth wire from tank to F/B.
Nigel.
An American living in a British body.
1971 Chevy Cheyenne 10 454
"In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell
"When injustice becomes law, resistance becomes duty" - Thomas Jefferson
No more pain.
03.12.60 -- 12.28.10
http://www.youtube.com/Eightbanger
eightbanger is offline   Reply With Quote
Old 04-05-2009, 02:44 PM   #5
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Re: Gas gauge help
before you take the sender and float out of the tank, remove the tan wire from the sender and see what reading you get. It should go past full. Then ground the tan wire on the side of the sender or any good ground and the needle should move to the left past empty. If these things happen then the problem is in the sending unit or float.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
