Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > All 4x4 Tech & Off Roading > 4x4 Projects and Builds
Old 04-05-2009, 10:53 AM   #1
lawnman50r
Father-Son build
My Son (11 Years old) and i just bought this truck last weekend and began work on it this weekend. We have 5 years before he is driving so we have the time to save $ and the time to get it ready. I think i am more anxious than he is.
I am also working on restoring a 1934 1.5 ton chevy.
I have spent alot of time on this site and love it, I know i will be needing help with a few things before this build is done.
lawnman50r is offline   Reply With Quote
Old 04-05-2009, 05:08 PM   #2
drivethechevy
drivethechevy's Avatar
Re: Father-Son build
it looks like a nice solid project!
what are your plans for it?
care to share some info about the truck
noticed the spare cab setting in the snowbank, is that a replacement or a parts doner
good luck on both restorations your son is very lucky to have to oportunity to restore a truck with his you
Trial and Error, its expensive but its a mistake i most likely wont make again
1971 chevy k10 custom deluxe
http://67-72chevytrucks.com/vboard/s...d.php?t=341257
1968 chevy k/10 fleet
http://67-72chevytrucks.com/vboard/s...d.php?t=334731
1948 desoto custom coupe fluid drive(family heirloom)
drivethechevy is offline   Reply With Quote
Old 04-05-2009, 09:01 PM   #3
msgross
msgross's Avatar
very cool project.. maybe my son (or daughters) and I will have a build someday...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-05-2009, 09:11 PM   #4
lawnman50r
Thanks, it is really a solid truck i think we lucked out finding this one. As for our plans we are going to keep it simple for now nothing radical, we are taking it down to the frame and planning on rebuilding every componet as we go back. After we strip both cabs we will decide which is best and use the other as parts doner. It came with a 350 engine, 350 trans, 44 front 12 bolt rear, 205 transfer. We were able to strip body off frame this weekend. start pulling drive train out next week.
Old 04-05-2009, 09:24 PM   #5
msgross
msgross's Avatar
that bed is worth a pretty penny.. don't mess it up.
The Garage:
Old 04-05-2009, 10:10 PM   #6
drivethechevy
nice and simple sounds like a great plan
sounds like your making good tare down progress already
nate
Old 04-09-2009, 12:16 AM   #7
CARZ1968
Bowties from Birth
CARZ1968's Avatar
Bought my 72 highlander the week my 12 yr old son was born, told my wife it was for him . He has decided he would rather have the convertible! Although he really likes the suburban.Probably because he could fit 20 of his closest friends in it. Good luck on your build.Treasure the time you guys spend together
68 K10 Burb aka "da bomb"
72 C10 SWB Highlander
97 30th anniv. Z28 Conv
99 Chevy Crew 454
11 Traverse AWD
CARZ1968 is offline   Reply With Quote
Old 04-10-2009, 08:18 AM   #8
lawnman50r
The time with them is mostly why we are doing this, last weekend we took it down to the frame, i will have pictures this weekend had to go buy new camera. As we tore it down everything is looking good. We will start rebuilding all drive train asap.
spw
Old 04-12-2009, 06:36 PM   #9
lawnman50r
Ok,we got alot done and now the real work starts and the questions. We striped both cabs and found the donor cab to be the better of the 2. We will now set all that aside and start on the drivetrain rebuild and frame. My first question on the front end, I want to have disc brakes. I have done some research and found that a front end out of a 1973 blazer will work, can i get some advice. I will rebuild the rear end, transfer case and the transmission myself. First auto rebuild so may have more questions. here are some progress pictures. Like i said the easy part is done.
1972 swb 4x4
1968 d100 4x4
1934 1.5ton chevy
1924 white
Old 04-14-2009, 10:11 PM   #10
lawnman50r
Can i use 1972 blazer axles so that i can have disc brakes on the front.
1972 swb 4x4
1968 d100 4x4
1934 1.5ton chevy
1924 white
Old 04-14-2009, 10:19 PM   #11
msgross
msgross's Avatar
What year is your truck? I would have thought that it did have disc brakes...
The answer is "yes" you can use any solid axle form a chevy up till IFS in the late 80's. I have an 82 corp 10 bolt in my 68. Be sure to match the gearing with the rear end though... pull the differential cover and look at the numbers stamped on the big ring gears to be sure (ie 41:11 = 3.73, just divide the numbers). The axles tubes are 3" on mine though so I had to pull a new top leaf plates to fit as well... and now I have a sway bar that came form the donor that works!!
The Garage:
Old 04-14-2009, 10:23 PM   #12
lawnman50r
The cabs are 72 i assumed the frame was also but i may be wrong. it has a dana 44 with drums.
1972 swb 4x4
1968 d100 4x4
1934 1.5ton chevy
1924 white
Old 04-14-2009, 10:24 PM   #13
msgross
msgross's Avatar
72 should have had disc... check your VIN on the frame to see if it matches the CAB... It's just inside the driver wheel on the top plate of the frame, near the PS pump area...
The Garage:
Old 04-14-2009, 10:28 PM   #14
lawnman50r
Thank you I will do that. Is there a place i can use serial# to check the year of frame, hopefully just wrong axle.
1972 swb 4x4
1968 d100 4x4
1934 1.5ton chevy
1924 white
Old 04-14-2009, 10:32 PM   #15
msgross
msgross's Avatar
serial # is only the sequence for the rest of the VIN (which had the year in it I think) so it might not give you any answers...
The Garage:
Old 04-14-2009, 10:45 PM   #16
lawnman50r
Thank you sir, If anyone can help me identify this frame I would sure appreciate it, I have pictures of it and i will be getting all #'s off of it. Thank you!!!
1972 swb 4x4
1968 d100 4x4
1934 1.5ton chevy
1924 white
Old 04-15-2009, 03:31 AM   #17
84 400
Sb 400 club
84 400's Avatar
you got a great one to start with. It is good to have him involved with the rebuild after all that time wrenching and rebuilding it he will have a real appreciation for the time and work you both put in.
It is kinda the oppest with me. I got my dad into rebuilding trucks and we currently have 3 projects going on. It can be fun some times and really piss you off at others but I am guessing in the end the long nights and agrivation are worth it. None of ours are done yet so I don't know but at least 2 are on the road.
Good luck with it and have fun!
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 04-15-2009, 10:56 AM   #18
drivethechevy
im not sure if there is really any differences between the frame but i am guessing the your frame is either from a 70 or someone swaped the axle from the 70
69 older had closed nuckle axles and there was a big ball right before the drums and that ball concealed the axle u-joint
in 70 the changed the design to open nuckle which made the u-joint vissible and gave 4x4s better turning radiuses but they still ran drum brakes
in 71 front disk brakes became the standard
from the pictures you have put up it looks as best as i can tell the you
have an open nuckle front axle which leads me to belive that the axle is a 70 if it has drum brakes
to confirm this for yourself just look and see if you can see the axle shaft u-joint inward from the drum setups
good progress on the tare down, you were lucky that your truk came with a good cab, locating nice cabs is getting to be a bit of work
Old 04-15-2009, 11:29 AM   #19
msgross
msgross's Avatar
you know what.. you can change the drums on the open knuckle axle over to disc without removing the axle...
You need everything from the donor axle from the spindle out.. Or you could pull the enite knuckle off and put new ball joints in as well.. That's what I would do unless you are lucky enough to find the same gear ratio...
You need
1. spindle (6 bolts holding it on the knuckle
2. hubs with bearings (rotor usually installed)
3. Caliper mounint bracket
4. Caliper
5. New rubber brake lines
6. adjustable proportioning valve or factory one to replace the distribution block below the MC
There are a few tech articles online.. I have some spindles and one caliper mount but it's not worth the shipping cost (heavy).
Find any dana 44 from a chevy for donor parts!
The Garage:
Old 04-16-2009, 10:40 PM   #20
lawnman50r
Well I got lucky again and i found a 1972 front end on craigs list with springs and all steering linkage in awesome shape for $100. So now I am back on track. I sure appreciate everyones help.
1972 swb 4x4
1968 d100 4x4
1934 1.5ton chevy
1924 white
Old 04-23-2009, 09:48 AM   #21
Burt4x4
Burt4x4's Avatar
looking at your frame it has to be 70 or higher. On the drivers side, the front spring hanger looks to have a strap welded across the front of the hanger. This was a factory change as the 69 model had a re-cal for that spring bolt braking and the driver loosing control of the steering. There was aslo a bolted on stop at the rear of that front spring. Years ago on an old site blazer-net.com someone had posted up a scanned copy of the re-cal letter from late 1969..anyway as for the front axle you can litereally bolt up any D44 or D60 from the 70's & 80's pickup or Blazer
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 04-30-2009, 04:08 PM   #22
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Wow that's an awesome looking project truck especially a father/son project! You have a great start on it for sure. Going to be an sweet truck when you get it all done. Keep up the good work! Good to hear that you scored a front end for it.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 05-09-2010, 09:58 PM   #23
lawnman50r
well, during the last year we haven't got alot done because of work being incredibly busy but i guess without work we wouldnt be able to do this. we got frame stripped, blasted and painted. front and rear end rebuilt, rebuilt the transfer case. hopefully we make enough money to install a newer 5.3 or 6.0 with 700r this fall. In the meantime we will get the cab ready for paint as we will be doing alot of little custom work to the cab. here are some pics of progress.
1972 swb 4x4
1968 d100 4x4
1934 1.5ton chevy
1924 white
Old 05-24-2010, 08:45 PM   #24
Conroe trucker
SWBs: 67 2x4, 67 4x4, 70 4x4
Great truck to start with.
You don't have to be in a hurry, he won't be driven too soon.....
FINISHED Project thread: 67 SWB 4x4
FINISHED Project thread: 67 SWB 6 cyl cruiser
Project thread: Road Toad 70 SWB Step, 4x4, 292, 3OT
01 C5 convertable
08 Z06
Conroe trucker is offline   Reply With Quote
