04-05-2009, 01:15 PM | #1 |
69 Fleetside
Interior gas tank fumes
I don't smell them often, but every once in a while I get a good whif of gas and was wondering if anyone has found the source of them? Is it the sending unit cap letting them out? I have thought about globbing on the silicone around it to see if that would cure the issue but just wondered if anyone has found the cause, since everything else is sealed an/or vented outside. Until I get the cash to put in a suburban tank I don't have too many options other than dealing with the death trap behind my seat. Any ideas?
04-05-2009, 01:34 PM | #2 | |
The Red Menace
Re: Interior gas tank fumes
1971 Custom 10 - 350/350TH - Pwr steering, gauges, Chrome front bumper, Chrome hubcaps, Door edge guards, HD rear springs (current) 1968 C-20 Custom Camper - 350/350TH (orig 327), Pwr steering & brakes, gauges w/tach (former) 1968 C-20 - 307/3sp column (Dad's when I was a kid) "Driving is like coloring. Things get messy if you can't stay inside the lines." |
04-05-2009, 01:46 PM | #3 |
454 MAKES IT ROAR
My 71 smelt of Gas in the cab allot, the Gas cap on mine is pressurised but it was not making a good seal as the rubber on the back had worn out, so I replaced it with a new pressurised cap and no more smell.
Nigel. An American living in a British body. 1971 Chevy Cheyenne 10 454 "In a time of universal deceit, telling the truth becomes a revolutionary act." - George Orwell "When injustice becomes law, resistance becomes duty" - Thomas Jefferson No more pain. 03.12.60 -- 12.28.10 http://www.youtube.com/Eightbanger |
04-05-2009, 03:49 PM | #4 | |
Over time, you are becoming desensitized to the gasoline odor and your gasoline odor problem is a worse problem than you think. Just ask your wife or girlfriend, (if you have a wife don't invite the girlfriend to come along at this time) to get in for a ride. First words will be, "It stinks like gas in here". Check your fuel lines for leaks also. Gasoline vapors travel quite easily and may be coming from your engine compartment.
'72 GMC custom camper 350/350 |
04-05-2009, 04:08 PM | #5 |
67 is sold
Yep, certainly not normal. I see some great advice above, can't add much more
04-05-2009, 04:30 PM | #6 |
20' Daredevil (Ret)
My first thought was a new gas cap, because that was my problem.....
04-05-2009, 05:17 PM | #7 |
its all about the +6 inches
check the rubber on the gas cap.
Slide the seat forward, removing it would be even better... its only a few bolts. Look under the sending unit... look for signs of liquid washing away the dust that is all over the tank. Then, take a flash light, and look where the filler foes into the tank. From years of idiots leaning on the gas pump handle, the solder frequently breaks at this point. Last edited by Longhorn Man; 04-05-2009 at 05:18 PM. Reason: add photo |
04-05-2009, 06:03 PM | #8 |
I built it
if your tank has evap. lines thats where mine was smellin' just replaced those and it fixed it.
'72 k10 lwb 454, th400, 205, d44ft, 12b rear, 4in skyjacker, 35x12.5-15 superswampers, 4.56, blazer tank. painless wiring harness '98 dodge 3500 12v 5sp 4x4. the truck that actually runs |
04-05-2009, 11:57 PM | #9 |
Hybrid67
Cap replacement was a necesary solution for me, too!!! Check the seal on the back of the cap and see how bad it looks. Because you sit right next to it while driving it seems as if its coming from behind the seat. Didn't figure mine out until I worked on it in the garage with the window down and the smell was very noticeable then.
