Old 04-05-2009, 02:55 PM   #1
hemihead
hemihead's Avatar
Need some rear diff help
I have two 6 bolt rear diffs.. the funny thing is the axle tube on each diff measure differently and I am wondering if some one shortened 6 bolt axles to fit in a 5 bolt diff.
The axel tube (measured from the center section to the inside of the square mouning flange) on one measures about 20" +/- 1/8" and the other axle measures about 21" or so.
Does any one know what a axle tube on a 5 bolt would be?
I want to switch to 5 bolt axles but was going to purchase the axles and drums from CPP. If I indeed have a 5 bolt diff, I'll go to the wreckers and purchase some used axles.
1967 SWB C-10, BBC 454, T400, 3.73 posi, 20" Coys
1972 K5 Blazer, SBC 400, 4 spd, 3.73, 6" lift, 35" mud grapplers
2011 Sierra Denali HD, 6.6 L Duramax, RBP 96R rims, leveled and Nitto trail grapplers,
2009 Acura MDX
hemihead is offline   Reply With Quote
Old 04-05-2009, 05:25 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Need some rear diff help
it sounds like the short one is a mid to late 1970 rear. Gm widened it in mid '70 in preperation for the wider 5 lug rear.
Old 04-05-2009, 09:40 PM   #3
hemihead
hemihead's Avatar
The rear is set up for tariling arms suspension. Did they have this past 1972.
2009 Acura MDX
Old 04-05-2009, 09:52 PM   #4
Green Machine
Green Machine's Avatar
The wide rear is the one you want to keep if swaping in newer 5 bolt axles from a junkyard. Aftermarket 5 lug axles are available for the shorter rear, but since you have your pick, use the wider one and get the used axles, much cheaper.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 04-05-2009, 11:38 PM   #5
Longhorn Man
72 was the last year for coil springs and trailing arms.
Old 04-06-2009, 10:09 PM   #6
hemihead
hemihead's Avatar
So do you guys think that for the shorter rear end I'll find 5-bolt axles
2009 Acura MDX
Old 04-07-2009, 05:27 AM   #7
JimKshortstep4x4
5 bolt axles are used in the longer rear end and will be too long for the shorter differential.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-07-2009, 11:21 PM   #8
hemihead
hemihead's Avatar
Are you guys saying the longer 6 bolt axles are the same length as the 71/72 5 bolt axles and therefore interchangeable?
2009 Acura MDX
Old 04-07-2009, 11:39 PM   #9
Longhorn Man
exactly
