04-05-2009, 06:54 PM | #1 |
350turbo to a 700r4 in a 86 pick
do i need to change my cross member to had a 700r4? in my 86 2wd pick up?
thanks |
04-05-2009, 06:56 PM | #2 |
Re: 350turbo to a 700r4 in a 86 pick
No you just have to relocate it. There should already be a set of holes there to remount it in the correct location.
04-05-2009, 06:57 PM | #3 |
thanks
04-05-2009, 06:58 PM | #4 |
No prob. You will need a new drive shaft too, or have yours shortened.
04-05-2009, 07:43 PM | #5 |
BAD BOW-Silverado XST
Good reading for your conversion.
http://transmissioncenter.net/700R4_Swap_Info.htm Your 86 has holes for the 700R4. If ya need a crossmember give me a shout. I have one collecting dust in the garage. I think it's the same as the 350th. It should have a over and under route of the exhaust pipe. |
04-06-2009, 08:54 PM | #6 |
if running duals, which side is over & under the crossmember? thanks
04-07-2009, 04:52 AM | #7 |
If I remember correctly, the driverside is under and passenger is over.
04-07-2009, 08:59 AM | #8 |
My 84 is done that way but in reverse. However it currently has the TH350 in it. I thought it was a hacked up exhaust job. Didn't know that they actually went one under and one through.
04-07-2009, 07:07 PM | #9 |
04-08-2009, 06:41 AM | #10 | |
04-08-2009, 08:31 AM | #11 | |
Happy to be here
04-08-2009, 09:43 AM | #12 | |
so thats normal? huh i thought it was just another hack job on this truck
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels 2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost |
