Old 12-22-2002, 11:06 AM   #1
superchevy
Got big-block?
superchevy's Avatar
Failed emissions test....NOX too high...??s
My '93 failed the Dallas County sniffer test Friday. My NOX levels were too high. Tech said that is usually an indication of too hot of a combustion chamber. Probable EGR failure. Might also be too lean.
I'm going back for a retest on Monday.
I've already pulled the intake off and cleaned EGR ports as well as installed a new EGR valve and EGR solenoid, and new AC spark plugs. Reset timing back to factory spec of TDC.
Anything else I can do?
Was told might be a plugged catalytic converter causing the high chamber temps.
Is my open element air filter pulling in too much air?
Any ideas?
Thanks for the help,
SC
'68 CST SWB factory 396/T400
buddy buckets, a/c, ps, pb
'72 Corvette convertible 454/4spd/ac, ps, pb
'73 GMC Sierra Grande short wide 454/T400 ps, pb, ac
'77 K5 Blazer black on red, 350/T350/NP205 ps, pb, ac all original
'78 GMC Sierra Classic short wide 454/T400 ps, pb, ac
'72 GMC Sprint SP454. 1 of 38 built.
'73 GMC Sprint SP454. 1 of 71 built.
'75 GMC Sprint SP454. 1 of 25 built.
SOLD! '72 GMC K25 4x4 468/4L80e/NP205
build thread
http://67-72chevytrucks.com/vboard/s...23#post4324423
SOLD!'55 Chevy gasser 496/4spd
build thread
http://67-72chevytrucks.com/vboard/s...96#post4324396
superchevy is offline   Reply With Quote
