Sierra Grande Club
Generator light on with key in accessory position
Like the title says when I put my key on accessory position the idiot light is lit.
I'm not sure what this means, I don't think it's supposed to be on. Can someone confirm this?. s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
![]() Join Date: Jul 2004
Re: Generator light on with key in accessory position
Might want to ask a moderator to move this to the electical section, to get a better answer, but I think that is normal for the light to be on in the acc position.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
I also think it is normal. Mine is the same./
Working on my first 1,000 post. I'm sure I'll get there before this project is over ![]() |
it is normal all vehicles do it even the new ones.
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
Sierra Grande Club
Does it also light in the run position? Mine doesn’t, only the oil light.
s/t
Sierra Grande Club
I think they only do it in the run position before you start it. (To check the light operation).
s/t
ahhh good point i just kinda skimmed the post. Mine isn't running or together at this point to check. Maybe his ign switch is boogered i don't think it should be on in acc but should be on in the run position for prove out.
normal to have light on in acc position // just the dummy light telling you it aint charging the battery
Sierra Grande Club
So far the sensuous says it’s normal. I just cant figure out why it wouldn’t also be on in the run position??
s/t
![]() Join Date: Nov 2006
because it only comes on when the battery isn't charging.
With the key in the run position and the engine not running the light should be on if not check to see if any other accesories are also off such as wipers and blower if so you may have problem w/ iggy sw.
Sierra Grande Club
I just checked, In the run position everything works. Lights (inside & out) fan, wipers, radio & only the oil light is on in this position.
s/t
#13 |
Be happy. My starter turns with the key in the acc position.
#14 |
Sierra Grande Club
Seems like it would make it some what theft Proof.
![]() s/t
#15 |
s/t have you checked your alt to verify that it's putting out with engine running the alt light is what supplies your alternators feild current to get it started once it starts putting out current the light goes out because there is 12v (nom) positive voltage at both ends of the light. Are there any mods to your charging system. since the light comes on in acc pos it shows that if is flowing to ground so it is possibly not getting power in run pos.
