Old 04-05-2009, 11:24 PM   #1
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
What air line fitting to use for rear bag?
What airline fitting are you guys using for the rear air bag? I was thinking about using a 90* fitting but am not for sure if there is enough room for it to turn in the frame rail. I am running RE7's in the rear of my truck with a c notch and 1/2" line, so the 1/2" line doesn't flex much. Pics?
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 04-05-2009, 11:35 PM   #2
Shane
Shane's Avatar
Re: What air line fitting to use for rear bag?
I used swivel 90° fittings on the rear. Tighten it up & check for air leaks before inserting the fitting in to the hole of the frame ... then you can turn the fitting whatever direction you need it to point.
Shane is offline   Reply With Quote
Old 04-05-2009, 11:38 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Swivel fitting? got a pic? I didn't see those on the SD site.
Old 04-05-2009, 11:56 PM   #4
hotrodhomi
hotrodhomi's Avatar
That's what I used. I got my fittings at the Parker fitting store in Sacramento
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 04-05-2009, 11:58 PM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Kewl, thanks guys!! I will get up first thing in the morning and check out 1 or both of our Parker stores here in town.
Old 04-06-2009, 01:58 PM   #6
dznucks
dznucks's Avatar
Let us know part numbers. I would like to get these swivel fittings too.
dznucks is offline   Reply With Quote
Old 04-06-2009, 09:11 PM   #7
AJohn6
Knuckle head
AJohn6's Avatar
I used the Legris 90* swivel elbow. Part#-442044, Vender# 3109 60 22. It has a 1/2" NPT end and accepts 3/8" tube. It is a "Push-To-Connect" fitting. It works well and is rated up to 290 PSI. the only thing is I had to order it from Fastenal. They are about $8 ea and only came in a box of ten. It worked out well I ended up using all of them.
Adam
'71 SWB/Step http://67-72chevytrucks.com/vboard/s...d.php?t=291750
2017 Crew Cab Silverado LTZ with 6.2l, 8 Speed tuned by RPM in Garner, NC
'00 Chevy 1500 6.0l Silverado Reg. Cab Short Bed
'09 Chevy 1500 5.3l Silverado Crew Cab Short Bed (SOLD)
1971 LWB on 2014 1 ton chassis, L96 6.0LS / 6L90E http://67-72chevytrucks.com/vboard/s...d.php?t=796785
1969 LWB C10- Future project, possible AWD C10 on a 2002 Escalade Chassis.
AJohn6 is offline   Reply With Quote
Old 04-06-2009, 09:29 PM   #8
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
I bought 2 of em today and left the receipt at my buddys shop where I'm doing the work and will try to post it tomorrow.
Old 04-06-2009, 10:18 PM   #9
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
It's a 90* swivel with a green prestolok fitting for the air line.
Old 04-07-2009, 09:59 AM   #10
dznucks
dznucks's Avatar
chevydog did you get them at the Parker store?
Thanks AJohn, will check those out too.
Old 04-07-2009, 09:27 PM   #11
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
yep, got them at the Parker store, but left the receipt at the shop, again. I also had to buy a bushing to thread into the bag, so I got a 1/2" bushing that threads into a 3/8" Prestolok 90* swivel, but has a 1/2" air fitting to put the plastic line in, because the fitting was sitting too low in the frame to thread into the bag. So the bushing brought it up about 3/4".
