I miss this truck.
Lifting be d from truck.
I'll probably do it by myself. I'm wondering if anyone has ever tried using an engine hoist. Pull a bolt from the front and back of each wheel well then use those holes to bolt a chain to. Also thought about using this method on the cab later on using the cab mount holes. Any input?
'07 GMC Acadia SLT. Sweet ride. '08 Crew Cab Z-71 short bed. Really like this truck A LOT. |
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
I cut a 4"x 4" long enough to fit under the bed rails. Slide it up against the front side of the middle stake pockets and then wrap a chain around the center of the 4"x 4" hook my engine hoist to the chain and lift it off. Works great!!.... WES www.ClassicHeartbeat.com
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
Dont use chain, try straps instead. Your sheetmetal will thank you. I might try going from the corner stake pockets if you are using a hoist. But, the best way is to invite friends over, one on each corner and lift it.
jku Cornville, Maine 68 C10 burb 42 Willys MB 46 Dodge WF-32 1.5 ton 53 & 56 Olds' 60 Cadillac 22 Dodge Brothers |
![]() Join Date: Oct 2001
With the engine hoist you can do it by yourself if necessary. I've only done wood floor beds with the wood out of the floor so there are many places to hook a chain or strap that won't hurt the sheetmetal.
Tom
'69 swb stepside in progress. '59 Corvette lifetime project |
I miss this truck.
Thanks for the input, fellas.
"Ochre Ogre"
I did it the same way that Wes did. Wouldn't do it any other way ever again..........
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
![]() Join Date: Jun 2002
I simply fabed a 4-way out of 1.5" aluminium tubing (steel would work to), put a eye bolt at each corner and 1 in the middle to hook to the hoist. Then use tiedown straps from each corner eye bolt to the bottom of bed floor. Worked great with no distortion to the bed assy., and is an easy 1 man operation. Works great for the cab too.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
I used 4 ratchet straps and went to the four corner bed pockets. If it's a little unbalanced the ratchet straps can then be used to level it out. Worked slick. No scratches. Check to make sure everything is unbolted. I found that somebody had welded an exhaust hanger off of the bed cross rail.
............................................................ 68 Chevy CST SWB w/LS1, carb & 700r4. Golden Anniversary clone with a few improvements. |
