![]() Join Date: Aug 2003
Seat Belts and Dash Pad
Hi everyone. Gotta couple of questions. I'm replacing my belts and changing to Black and need to know where to get the same type. I have a bench seat with the belt going through/between the seat (female) and on my left(drivers side) the male part retracts.
Not sure if these are factory. Any help would be appreciated. One other question; Is there a thread or FAQ on changing the dash pad? Or does anyone know where I can get some pics of doing the job, please? Thanks in advance.
1968 SWB. GMPP 350/350 Turbo Trans, Edelbrock Performer & Carb. Hedman Hedders, Hooker Aerochambers Mufflers. Tuff Stuff Alternators. Remember, no matter where you go, There you are. Gary |
SWB 4x4 Collector
![]() Join Date: Jun 2001
Re: Seat Belts and Dash Pad
The only way to remove a dash pad, is to take out the Gauge Cluster and Glovebox, maybe even the radio as well. It is bolted to the metal dash behind the pad by like 7 or more? Bolt that are on the back side.
To find black seat belts that are GM, you will need to look in salvage yards, on the parts board (but they go fast), or ebay. Trevor
TREVOR ![]() ![]() ![]() ![]() ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=624819 ![]() ![]() :2004 Jeep Wrangler Rubicon (daily driver) WTB: 1968-70 Cruise Control Lever |
if youre not worried about being correct you can get some individual seatbelts in black at the chain parts stores. they come in different lenghts i added a set the center of a bench seat and they worked great. they come with the bolts and everything you need to install. but they arent factory.
Thanks for the help guys, I appreciate it.
its all about the +6 inches
when you have your new dashpad in hand, look on the back/under it and you'll see exactly where the speed nuts are that hold it on. If memory serves, you'll need a 5/16 and a 3/8 socket... 1/4 inch drive and deep sockets worked best for me. If it is an A/C truck, you WILL cuss.... a LOT.
Then there's the phillips head screws on the front too, but I'm sure you saw them already. |
I am a Referee of life.
You will have an easier time on the dash pad if you have several 1/4 in extensions and maybe a swivel or 2.A deep socket will fit the speednuts better and is easier to get on them.Unless it's already been replaced you want to get a new glovebox since it may be brittle and break when you take it out.If you have the 7 hole cluster be careful of the oil line.While the cluster is out clean the contacts and check the bulb sockets and bulbs.
Don't cinch the speednuts down too tight when you put the new dash pad in or you will get an uneven/warped look.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 04-08-2009 at 06:31 PM. |
Hybrid67
Check out LMC for the belts. Repros close to original design in almost all color options for 67-72 interiors. Decent pricing too.
69 Fleetside
![]() Join Date: Mar 2009
just got LMC 3 point belts that look nice, but I haven't installed them yet - and a Brother's dash pad that isn't too bad for only $67 now that it's on sale. It comes with the underside bolts but does not include the front face screws, you need to order those seperate.
