Old 04-06-2009, 10:23 AM   #1
ljackson
ljackson's Avatar
Just bought a 64 long box
Hi, I bought a '64 long box last week that my 14 year old son and I are going to restore. I have a few questions. First, the fresh air and heater blower controls. Our pickup has the fresh air cable, although it needs to be replaced. There is a second hole in the dash panel. Is that where the blower control cable goes? Do you pull the cable for high, med and low?
Second, to fix sagging doors can you replace the hinge pins and the whole hinge?
Third, there are several vendors that sell parts listed on the forum. Do you have any favorites for parts for a pickup like mine?
And last (this post) after reading stuff on this forum I think there is an inner and outer rocker. The (top) outer is rusted through where it meets the floor. Should I assume the inner needs replacing if the outer does?
Thanks for your help,
Eugene
ljackson is offline   Reply With Quote
Old 04-06-2009, 10:37 AM   #2
LILRED66
LILRED66's Avatar
Re: Just bought a 64 long box
Eugene
Eugene:
Congratulations on the purchase and enbarking on a restoration project with your son. Welcome to the forums from Kansas City, KS.
With regards to your heater/defroster set-up, it sounds like you have a Thrift-Air set-up, which consists of a single pull knob on the dash bezel with a two-speed fan blower switch. If that is the case, there is only only means of control at the dash. By pulling the knob out, you control the volume of air...by turning the switch from high to low you control the speed. In order to get defrost, you must flip the knob on the plenum box under the dash to divert air to the two dash-mounted diffusers.
Here is a comprehensive list of suppliers that provide parts for '60-'66 Chevy trucks and each of them offer a catalog:
www.bowtiebits.com
www.lmctruck.com
www.classicparts.com
www.oldchevytrucks.com
www.ecklerstrucks.com
www.gspp.com
www.truckandcarshop.com
www.harmons.com
www.oldmusclecars.com
www.classicchevroletparts.com
www.classicindustries.com
www.bobschevytrucks.com
www.brotherstrucks.com
www.mar-k.com
www.wheelvintiques.com
www.totallystainless.com
www.earlyclassic.com
www.horkeyswoodandparts.com
www.raybuck.com
www.americanclassic.com
www.yogisinc.com
www.rbsauto.com
www.obschevy.com
www.cheyennepickup.com
www.chevypickupparts.com
There are also many members that sell good, used parts for these trucks.
Door hinge rebuild kits are available, as well as, new and used door hinges are available.
In order to deterimine the condition of the inner and outer rocker panels, take a scratch awl, ice pick or some other sharp object and poke around the inner and outer rocker panel to determine where the material is compromised with rust. To access the inner rocker panel, before removing the outer rocker panel, you can see it from underneath the truck. If the outer rocker panel is removed, you can see it from both sides.
I hope this information is helpful and keep us posted with lots of photos. Good luck with your project.
LILRED66 is offline   Reply With Quote
Old 04-06-2009, 10:40 AM   #3
Corts60
Just here to tinker
Corts60's Avatar
Congratulations on your project and welcome to the board!
Old 04-06-2009, 12:25 PM   #4
kizer
Its Deja Vu time again
kizer's Avatar
Congrats and do yourself and us a favor. Get a photobucket account or something of the sort and take tons of photos. You will refer to them a lot and its much easier rebuilding from photos than memory.
As well we like photos.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 04-06-2009, 12:35 PM   #5
MacAttack
283 Drama Queen
MacAttack's Avatar
You have no idea.
WELCOME to the board from SoCal.
Mac.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 04-06-2009, 06:30 PM   #6
ljackson
ljackson's Avatar
Smile Re: Just bought a 64 long box
Thanks for the info received so far. I did make a website with pics. Just a few pics of the exterior. I'll be adding more soon. I'll take some of the dash controls and under dash tomorrow.
Eugene
http://zacks64longbox.shutterfly.com/
Old 04-07-2009, 09:43 PM   #7
TimE
Hey Y'all!!
TimE's Avatar
Welcome...
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 04-07-2009, 09:59 PM   #8
Chevy Fleetside
Chevy Fleetside's Avatar
Looks like a hole someone drilled. That should not be there. Only one hole for the pull knob.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 04-08-2009, 09:52 AM   #9
kizer
kizer's Avatar
From the look of the photos you picked up a rather decent condition rig.
Yeah it looks like somebody punched a hole in the dash for that hole. Probably for a toggle switch.
