Blazer/Jimmy original rollbar ? pics
I pulled this from a Blazer where I was told it was an original.It matched the color of the truck and has padding covering the top rail. This padding has been glued together at the seam. Can anyone verify if it is an original ? I also removed the luggage rack that has fiberglass ends that are the same texture and molded to fit the top. It also had 3 steel bars running lengthwise to the top and were painted to match the color of the truck...I don't have any pics of that but can get them...
Thanks , Charlie
71 Hugger Orange Blazer..currently under off-frame resto to her original beauty. |
2nd pic
full pic of rollbar
PROJECT 7DEUCE
![]() Join Date: Dec 2002
When i bought my 72 blazer it had a bolt together type of roll bar and i was told it was factory....But i dont know for sure ....
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
![]() Join Date: Feb 2001
Doesn't look like mine. Mine is mounted on the top of the wheel well.
L.E.D. Freak
The roll bar looks the same as mine and I was told it was factory also.
Specializing in Custom L.E.D. inserts. http://www.ccled.com/ Contact me @ blazer2wd1972@hotmail.com (406)675-8082 or Joel @ jmcwaters@eps-corp.net 1972 2wd Blazer, 350/700R4/3:73 posi, err & Custom L.E.D. inserts! LOL |
The only type of "factory" roll bar I have ever seen was a single hoop with no down bars in the 73-75 Blazers. Does it say "Rollbar" on the glovebox option sheet? If not, not factory. The bolt together bar that goes behind the wheelwell is the Smittybuilt. I have that bar with their cage conversion. My Dad bought the Jimmy from the original owner in '77, and I have paid close attention to these trucks for 25 years and have never seen a "factory" rollbar. Not to say one might not exist, so if you have it on your option sheet, please let us know option # and rollbar style. This pic was taken in fron of my neighbors house in 1991.
PROJECT 7DEUCE
That looks like my blazer and the roll bar i had i got steel wheels though..
![]() Join Date: Jul 2002
That looks like the roll bar I have in my blazer. I was told it was factory.
