04-06-2009, 11:51 AM | #1 |
Big Block Fuel Injection?
Hey all!
I am posting here because of the increased traffic. The suburban has a 402 Big Block and I have a few questions. Has anyone done fuel injection on this setup?I think some fuel injection was done on the 454 (or was it TBI?) Would a setup out of a junkyard work on the 402? I know the displacement is different, but what if the 402 had a cam, or even a 454 crank in place? Is there a Big Block Fuel Injection setup that doesn't cost a fortune? I thought I read about some vortec Big Block heads. Is there such an animal? I'm looking to make the Suburban a bit more driver friendly for my wife and am trying to figure out some different options. Cost wise it might be cheaper to put a 5.3 in it, but I want to be able to tow with it and I think I would like to keep the Big Block. I know I could just throw a 454 in it, but again, I kinda like the idea of keeping the original 402, or maybe making it a 427.... What are my options guys? SHawn
1972 C20 Suburban- Big Blue Betty '56 Chevy Bel Air Sedan- Frame up Restoration -What would you attempt to achieve if you knew you could not fail?- -I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door- R.I.P. EAST SIDE LOW LIFE |
04-06-2009, 12:03 PM | #2 |
Re: Big Block Fuel Injection?
I just sold a couple weeks ago a 2000 model vortec with all the multiport fuel injection and everything. the intake pattern is the same on older to newer models fortunatley they are not like their small block counterparts and changed designs every few years. You might want to see if you can scavange the fuel injection off something like that if you want miltiport or you can do TBI farily simple and cheap.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
04-06-2009, 12:43 PM | #3 |
Watch out for your cornhole !
Any 454 from 87-95 will have your TBI parts. Get it all if you can.
You will likely need a custom chip to get best performance though.
04-06-2009, 01:47 PM | #4 |
Thnx guys.
Tx, I haven't forgotten about the brackets. I just can't get them off until I can park the burb for a few days. Right now it needs to move everyday. I already have you a shirt!!
04-06-2009, 01:50 PM | #5 |
Rods
holly projection is also an option
04-06-2009, 02:25 PM | #6 |
You might want to look at a custom setup,It will not be cheaper than the stock TBI setup, but it wont be used, and will be much easier to tune. I would find a good local race shop that does that kind of work and look at something like this:
http://www.professional-products.com/EFI_3.php |
04-06-2009, 02:27 PM | #7 |
I just found a local guy that will sell me one for R&D for 1300.00 jobber price will be around 1650.00
04-06-2009, 04:20 PM | #8 |
That is probably a good kit, but I was hoping for something a little less expensive. If I was to spend that much I would prefer not to buy TBI.
So, has anyone used a kit for a small block, and drilled out the intake spots on ay an edelbrock intake. Seems kinda simple, but if you have to have the computer reprogrammed anyway, why couldn't it be reprogrammed with all new parameters for the big block. Say a system from an LS1 or even an LTI. You need sensors,(MAF sensor, TPS, IAT, TIMING, and knock) and injectors with rails (injectors and rail could be custom made, even by using something other than a rail), Intake (edelbrock Performer with injector Bosses) and computer and wiring (off donor vehicle), and o2 sensors. Am I way off base? Coould a small block computer be reprogrammed for a big block? Does the computer even know what size the engine is? It seems that the computer monitors the air/fuel mixture and learns at different Throttle positions and Air Temps what the injectors need to give in order for the mixture to be right. THen the knock sensor would retard or advance the timing based on what the knock is doing. AM I Crazy? Am I oversimplifying it? Shawn
04-06-2009, 05:28 PM | #9 |
The Edelbrock pro-flow is plug and play with everything included. It does cost around $2,000 and you get a device with it so you can do your own programming of the computer. I put one on my 383 and it works great.
69 Chevy 4x4 383 Power |
04-06-2009, 05:45 PM | #10 | |
04-06-2009, 10:22 PM | #11 |
That's a pretty good price. Those weren't that cheap last time I looked.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ |
04-06-2009, 11:25 PM | #12 |
THat isn't for the whole kit. The whole hit runs over 2k. That is just the intake manifold and a couple of parts.
Come on people!! Lets be creative and come up with a way to use what we can find for cheap! I know all those other systems are nice, but I'm looking for budget minded. Any ideas? Shawn
04-07-2009, 07:33 AM | #13 |
Rods
well When I was building inports I would tune the cars myself. there are lots of products out there. microtech. haltech. sds. aem. ect..... these you can adapt to a stock system and tune. some are almost self tuning. and some of these kits are about a grand. ebay even better.
04-07-2009, 08:12 AM | #14 | |
04-07-2009, 08:20 AM | #15 | |
04-07-2009, 09:01 AM | #16 |
Fast, cheap or reliable, ........ sorry you can only have two of those at once sir, LOL
04-07-2009, 09:42 AM | #17 | |
What all is needed? Injectors (8) MAF or MAP (which is better?) knock sensor temp sensor iat sensor tps sensor 02 sensors (2 or 4) (or get a bypass kit) timing sensor of some type? (is this necessary?) Shawn
04-07-2009, 10:24 AM | #18 |
My go fast friends modify an aluminum intake by drilling holes and welding bungs on them, then use a 45% aluminum elbow to the throttle body, weld a bung on the exaust for o2 sensor, and use a Ford EEIV ECM/aftermarket harness for the brain, as they are much easier to program and free if you want one. ( I know some guys on here are fuming, but in aftermarket EFI, and racing, the General lost a step when the 5.0 Fox bodys stepped up to the starting line in 1986) as a matter of fact now that we are talking about it, I just might have to try this on my Suburban here in the nexxt couple of weeks, I have almost everything I need in the basement...Hmmm glad you pressed this a litle farther.
Edelbrock Vitor JR. intake free, 350 Chevy free, 700r4 free, wiring harness free, EECIV ECM free, assorted sensors/ labor a couple hundred bucks, Watching Die Hard Chevy guys jaw drop in wonder when I tell them what runs it, PRICELESS . LOL |
04-07-2009, 10:37 AM | #19 |
I'M TRUCK CRAZY!
good question. I am interested in seeing if you can come up with the stuff to do it from a yard. I know you should be able to.
Is a 6.0 a small block? Isn't there a 7.? out that is a big block? I know that would be changing everything though. |
04-07-2009, 10:44 AM | #20 |
Location: Sunny, Florida, some might call it South Alabama
6.0 and 7.0 are both small blocks. The 7.0 is just a stroked and bored 6.0
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
04-07-2009, 10:57 AM | #21 |
This is a little info I dug up, the first one is a little fancy, but you should be able to do the same with stock stuff.
http://www.fordmuscle.com/archives/2...ion/index2.php http://www.fordfans.cz/download/manual/eectch98.pdf |
04-07-2009, 11:02 AM | #22 |
The size of the engine is not relevent, except for air volume, which should be compensated for with a larger dia. throttle body? and fuel delivery, wich is a product of pulse length, and fuel pressure, all of that is programable in the ECM. and injector size.
The other way to look at this is the FI 460 Ford, It may have the properly sized injectors, and air delivery program built into the computer? |
04-07-2009, 09:36 PM | #23 |
If you wanted to play with tuned port, the distributors are the same BBC(tbi) to SBC(tpi or tbi). I thought about doing this, but didn't want the hassle of figuring out a TPS that would work on top of a converted carb intake and having someone try to make a chip for something so far out of the stock parameters.
That and the 454 TBI system I got kind of fell into my lap for cheap. I really like it and it makes pretty good power even without a custom chip.
04-07-2009, 10:28 PM | #24 | |
Rods
04-08-2009, 08:25 PM | #25 |
sufficiently talented fool
I have a TBI setup off of a 1990 454 V3500 pickup. It uses an adapter tohat bolts right to a 4 barrel intake. I have the whole setup minus the intake, knock sensor, and O2 sensor. PM me if interested and I will post it on the parts forum.
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
