Old 04-06-2009, 03:10 PM   #1
truckintexas
Tilt Column Lower Bearing
What holds the lower steering column bearing on the shaft? It looks to me like the adapter, retainer, and spring, have nothing to do with it?
Anybody know?
truckintexas is offline   Reply With Quote
Old 04-06-2009, 08:11 PM   #2
KevsClassics
TILT COLUMN GURU
KevsClassics's Avatar
Re: Tili Column Lower Bearing
Anybody know?
Hey Michael so we meet again. There is a large flat washer and a spring goes between bearing and intermediate shaft. Same set up on a non tilt.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
02 Silverado ext cab. DD
RIP EL JAY
KevsClassics is offline   Reply With Quote
Old 04-06-2009, 09:18 PM   #3
truckintexas
Hey Kevin,
I kept trying to make the bearing sit down into the plastic "adapter". It just didn't fit.
But what you're saying is that the flat washer and spring hold the bearing in place. And I guess the adapter kind of keeps it centered?
Michael
Old 04-06-2009, 10:17 PM   #4
KevsClassics
TILT COLUMN GURU
Correct. But the bearing does snap into the plastic retainer about a 1/4 inch
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
Old 04-07-2009, 05:25 AM   #5
JimKshortstep4x4
A spring is not used on the tilt column lower bearing.
The lower bearing snaps into the plastic retainer. The plastic retainer has to be out of the column in order to get the bearing to snap in. Heating up the plastic in hot water helps but it can be a tight fit.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 04-07-2009, 09:24 AM   #6
truckintexas
Thanks guys.............
Michael
Old 04-08-2009, 04:15 PM   #7
truckintexas
Re: Tilt Column Lower Bearing
Update....did what you said....heated it up a little in a cup of hot water. Laid it on top of the retainer......eye-balled level.....one tap with a hard rubber mallet and it jumped right in...thanks again guys.
Old 04-08-2009, 04:31 PM   #8
truckintexas
Kevin, I'm finally thru with my column rebuild. I truly respect you guys that do more than one of these. I put new bearings (all three) in mine and greased them well. Should there be any noise when I rotate the shaft? Or will there be a little noise because they are all three the unsealed ball bearing type. Also, the lower bearing seems to be making a little more noise than the upper two. What kind of grease do you use?
Michael
Old 04-09-2009, 12:00 AM   #9
KevsClassics
TILT COLUMN GURU
Michael
I use wheel bearing grease. You might here a little noise when you bench check it but not when it is installed.
Instagram
kevs_classics64
64 Impala SS Conv
72 Blazer 2wd
75 Jimmy 2wd
63 Belair wagon
RIP EL JAY
