New style wheels
Here's a question. I know this came up before to some degree but I can't find that thread.
I have access to a nice set of 20" wheels off a 200x Tahoe (6-lug). Correct me if I am wrong but the newer style wheels (88+) have a different offset so they would sit in too far on a 73-87 truck? I am going to convert my CC to 1/2ton suspension and already have a 6-lug rear with newer 3.73 gears and an eaton posi. I also thought I had read that ECE or someone like that made a 6-lug rotor aimed at the 67-72 guys that convert their front suspension to the 73-87 style parts. Could I use the ECE 6-lug rotors, my existing 6-lug rear-axle and some spacers to mount these wheels on my truck?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Cheyenne Super
Re: New style wheels
I was told to get 73-87 3/4 ton lower a-frames and 88-92 3/4 ton (6lug) spindles/rotors/brakes, (I don't remember what brake lines you will need) to
do the swap. You allready have 3/4 ton a-frames/lca so all you need is the 88-92 spindles and ? brake lines. |
If those are the wheels you want , look into some Billet adaptors . They can be had for about $150 a set I think and come in varying thicknesses . If they make that adaptor , With the offset of the newer wheels , you could get adaptors to go from 5on5 to 6 on 5.5 and they would sit right in your wheelwells . Just a thought .
Frank
Born and proudly residing in a Red State ! |
