![]() Join Date: Mar 2009
need 70 4x4 parts
edited by moderator
Re: need 70 4x4 parts
I'm not sure but that is probably a wreaking yard only item. I believe that even the 2 WD with leafs will work.
69 Chevy 4x4 383 Power ![]() Last edited by Longhorn Man; 04-06-2009 at 10:23 PM. Reason: removed the quote from the initial WTB |
![]() Join Date: May 2003
I have a pair of the u-bolt plates off a 70 1/2 ton pick-up.
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
how much?
$25 plus shipping.
Gary
souds good to me. give me a call 215 805 4851 and we can work out the details or leave your number and I'll call you. My name is jeremy
jeremy
Give me a day or so. I have another set, and want to make sure there both from a 1/2 to and see witch ones are in the best shape for you. Then I'll send you a PM. Gary
very cool. thanks alot and I'll talk to you tommorow.
I went down in the basement and found them right away. Both are for 1/2 ton and on set looks very good, surface rust only, no scaley rust. Just to be sure ?
You have the ones that go under the axle with the squared off u-bolts the drop down from the top over the leaf springs ? Gary
I will have to check later tonight and get back to you in the morning but I know they are under the axle and the u bolts drop down from above.
![]() Join Date: Dec 2008
I had the same question about a week ago. I found some in local spring shops. I haven't bought them yet so I don't know the quality but they may be better than originals from what I saw on websites.
I am still going to buy the set from custom/10 for now, but let me know how the others look after you get them. If they are good quality and look like a heavier duty set I may get them later as I plan on a lift kit down the road.
#13 |
Designated A-hole!
I see several problems with this thread. First you need to be a subscriber to post a WTB. Second all buying/selling belongs on the parts boards, whether you're a subscribed member or not.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. ![]() We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
