Old 04-06-2009, 04:32 PM   #1
vasquezmrysvll
"the other guy"
vasquezmrysvll's Avatar
inline guys...i need help
i need some measurements for the oil dip stick. the PO took a small block stick,cut it and stuck it in(with no indicator marks!). there appears to be way too much oil in this thing.i cant seem to find a new or even used one anywhere? a pic of the stick with a ruler will be much appreciated. also, where can i find the timing mark on the balancer?
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE"
vasquezmrysvll is offline   Reply With Quote
Old 04-06-2009, 05:47 PM   #2
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: inline guys...i need help
Here's a few shots of mine from my 250, I hope this helps you out.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 04-06-2009, 05:55 PM   #3
vasquezmrysvll
"the other guy"
thank you SO much! are there any indicator marks? like add a quart?
Old 04-06-2009, 06:04 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
There was and I tried to get a shot of them but it wouldn't turn out on the photo...
(running out to the garage...)
Okay it looks like this:
....(.5")....(1")....(1.5")....(2")
....ADD.....................FULL
The "A" begins at the .5" mark on the tape measure, and the last "L" ends at the 2" mark.
Does that make sense?
-Nate
Old 04-06-2009, 06:13 PM   #5
68gmsee
Active Member
68gmsee's Avatar
Here's mine...
68gmsee is offline   Reply With Quote
Old 04-06-2009, 06:15 PM   #6
68gmsee
Active Member
68gmsee's Avatar
I forgot to add. Mine is a 1968, 250 not a 292.
Old 04-06-2009, 06:24 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Good Lord, you fellas are measuring your dipsticks and posting pictures on the internet. This place has gone downhill !
Old 04-06-2009, 06:31 PM   #8
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Welcome to the dark side....
And to add, mine is from a 1969 250.
-Nate
Old 04-06-2009, 07:00 PM   #9
vasquezmrysvll
"the other guy"
well, mine measures 11.5 from tip to where it seats on the tube? and the tube coming out of the block measures 2 7/8 inches? mine seems to be way off?for the record my engine came out of a 64 impala. its a 250
Old 04-06-2009, 07:08 PM   #10
68gmsee
Active Member
68gmsee's Avatar
Easy to find out if it's off. Just change the oil and filter, add the recommended amount for a 64 Impala 250, run it for a few minutes. Let it set for a while, check the oil again.
I did that on my 1975 Impala 350 engine that I put in my 69. Dipstick was an aftermarket.
Old 04-06-2009, 07:35 PM   #11
vasquezmrysvll
"the other guy"
where might i find those specs? i did a search and came up with nothing.
Old 04-07-2009, 08:35 PM   #12
68gmsee
Active Member
68gmsee's Avatar
My manual shows 5 qts with oil filter change for a six cylinder '65 Impala. It's the same on all 250's.
Old 04-07-2009, 08:44 PM   #13
vasquezmrysvll
"the other guy"
thank you
