Old 04-06-2009, 07:06 PM   #1
Hard Luck
I've got grease on my mind.
Hard Luck's Avatar
Specs needed
I just have an easy question. Need the upper ball joint bolt torque specs and the spec for the castle nut at spindle.
I have the service manual but it has all the numbers crossed out and refers me to an update that is not in the book.
Hard Luck is offline   Reply With Quote
Old 04-06-2009, 07:13 PM   #2
Hard Luck
Hard Luck's Avatar
Re: Specs needed
Sorry, forgot. 69 Chev c-10 with drums. Thanks again.
Old 04-06-2009, 10:26 PM   #3
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Specs needed
Wild guess, about 75-95 lb. ft. tq. Wheel studs are about 85 -95 for a 1/2" wheel stud.
2 wrongs don't make a right, but 3 lefts do.
66 Chevelle Malibu 406ci, 573hp, 10.99@121mph
96 Chevy Silverado Z71
72 GMC 1500 Super Custom LS 6.0/4L65 on airride
http://www.cardomain.com/ride/707879...mc-c-k-pick-up
chevydog66 is offline   Reply With Quote
Old 04-08-2009, 12:25 AM   #4
Hard Luck
Hard Luck's Avatar
Re: Specs needed
O.K. I got it. 10ft/lbs on the 1/4" bolts at the A-arm. 65ft/lbs on the castle nut on the spindle. Thanks.
Old 04-09-2009, 02:30 AM   #5
chevydog66
GM ONLY BABY!!!
chevydog66's Avatar
Re: Specs needed
ya somewhere around here there is a tq. spec chart. Just make it tight. Dont back it off. you will lose the preload if u do.
Old 04-09-2009, 10:05 AM   #6
Shane
Shane's Avatar
Re: Specs needed
tighten the spindle nut while spinning the rotor ... tighten until rotor will NOT free-wheel ... back off spindle nut to the closest cotter pin hole.
Mechanics have been using this method for YEARS with most not even knowing what "pre-load" is.
Sorry, but can't help on the ball joint fasteners. I can't see where it would be that critical considering the bolt really have nothing to do with the movement mechanism of the ball joint. But that's just an assumption on my part.
Shane is offline   Reply With Quote
