04-06-2009, 07:07 PM | #1 |
profeshinaly unimployed
fenders
i have a 82 but i really like the fenders off of a 79 so what im wondering is can i take the front fenders off of a 79 and have them bold right up to my 82...im thinking of just going to a junk yard and swapping them out or something
"having mud flaps is like asking for a smaller trophy" |
04-06-2009, 07:09 PM | #2 |
Real Projects never die
Re: fenders
unless you swap everything firewall foreword, no. Why do you like the 79 fenders better?
Ill put it this way, ive got a few lawn ornaments My name tag says Ryan KansasTwister On other forums
04-06-2009, 07:11 PM | #3 |
Re: fenders
idk they just look more beefy
04-06-2009, 07:28 PM | #4 |
Robert Olson Transport
Re: fenders
the whole thing is different including the wipers cowl etc... you would need the rad support too....
04-06-2009, 07:33 PM | #5 |
Re: fenders
man are you foreal i thought they would just bolt up cuz they look real similar
04-06-2009, 07:55 PM | #6 |
Re: fenders
04-07-2009, 03:36 AM | #7 |
Cheyenne Super
Re: fenders
It can be done, it's lots of work, and you would need a doner truck.
It would mostly bolt on, but the wiper shafts would need switched, and the radiator may not fit the core support. Round headlight front ends are stronger, but heavier and more prone to rust. Unless it keeps you awake at night, I think it's fine like it is. You can get those crystal clear headlights and signal lenses from LMC that will make your front end look tight. |
04-07-2009, 03:58 AM | #8 |
Laid back freak
Re: fenders
If your wanting to swap a 73-80 nose your gonna have to do alot .The 73/80 hood hinges are bolted to the fender and the 81-7 hood hinges rest in a set of slots on the firewall once closed.Plus like someone here mentioned the 73-80 has just the hood and a 81-7 has a 2 piece hood and cowl panel.Your gonna need a entire front clip from a 73-80 to make it work and do what i did to this 85 cab here pictured.Plus your going to want to weld up the holes in the cowl to smooth it out as well. I`m swapping a 85 cab back to a 80 with the dash,and the 2 hood adjustment bolts on the sides.I kinda went overbored and welded the entire front seam up as i did have to replace some rotted sections in the firewall.But if your up to the challenge its rewarding once done i think.
thanks pat
1980 chevy c10 step side restomod, 1970 cougar convertible 1 OF 24 ever built: 2014 Hyundai Tucson limited (daily driver). Last edited by 80stepsideguy; 04-07-2009 at 04:00 AM. |
