18 Till I Die
Brake light wont go off?
We just did the brakes on the 72, and we bled the whole system starting at the farthest wheel and so forth. The brake lighe is on in the dash. It is hooked to the porportioning valve. Can it be reset? or whats my next corse of action?
2011 GMC Acadia 1969 GMC BBC LS7 2007 GMC Crew Duramax 1987 Camaro Iroc 350 Tuned Port Injection 42000Km 1987 Chevrolet Silverado 350 TBI 1987 Chevrolet Silverado 350 TBI(yes 2) Take me drunk, I'm too home... ![]() |
its all about the +6 inches
Re: Brake light wont go off?
try stomping on the pedal real hard.... like you're doin 100 MPH and a moose jumps in front of you. That's how you reset the piston in the proportioning valve.
Longhorn Man is right on,that should solve your problem.but should the motor be running are not or does it make any difference.
18 Till I Die
Well I will give it a try. If that dont work then what?
Sorry Jim,I hit "edit" instead of "quote" and posted this (v) in your thread.All fixed now.
I`d imagine if you`re going 100 mph it would mostlikely be running. ![]() Then again,could be a mountainside and that`s why the moose didn`t hear you coming. ![]() Nah,just funnin`.I`d do it running to pressurize(depressurize?I`m confused)the booster and have full pedal pressure. Try this and go from there.
Moderator
![]() Join Date: May 2007
I just did re-did my brakes the other day, and had the same thing happen. Do as LHM suggested, and all should be well.
sharp as a marble
![]() Join Date: Jan 2007
RIGHT ON LONGHORN!!! I wonder if the fluid coming out of the rear wheels is more of a trickle than the gush that the fronts have? My bet is that is true. Do what Longhorn suggests, and then try and bleed the brakes again. I would hope there would be more pressure coming from the rear wheel cylinders after the Longhorn stomp. huumm, wonder if I just created a new dance.
