Old 04-06-2009, 10:07 PM   #1
chrislehr
Engine n00b
chrislehr's Avatar
Need help on carb/intake mani picking
I know nothing about matching this up.
buying a 350 .30 over off CL, and need a mani/carb to match.
Going to be mated to a powerglide at first, a th350 later in life.
My mechanic's picks:
http://www.jegs.com/i/Edelbrock/350/7101/10002/-1
http://www.jegs.com/i/Holley/510/0-80450/10002/-1
Thoughts? Im fine spending +/- $100 on the combo...
chrislehr is offline   Reply With Quote
Old 04-06-2009, 10:36 PM   #2
eseaton
eseaton's Avatar
Re: Need help on carb/intake mani picking
I am running a stealth intake and a carter 750 on mine. It is a 383 stroker punched .030 and a 3/4 race cam. Summit shows the intake for about $140.
eseaton is offline   Reply With Quote
Old 04-06-2009, 10:58 PM   #3
Jim_PA
I'd go with the standard performer if not building a wild 350.
I'm partial to quadrajets.
Jim_PA is offline   Reply With Quote
Old 04-07-2009, 08:21 AM   #4
68Stepbed
68Stepbed's Avatar
This would be my suggestion. I have this combo at it works great. The Street Avenger series are great street carbs.
http://www.jegs.com/i/Edelbrock/350/2701/10002/-1
http://www.jegs.com/i/Holley/510/0-80570/10002/-1
Matt
68 C10 stepside, LS1/700R4, TCI Engineering suspension system
68Stepbed is offline   Reply With Quote
Old 04-07-2009, 10:35 AM   #5
Gleekr
depends what you want-
max street power (or if going to upgrade) go with a dual plane air-gap type (weiand 8501/edelbrock 7501) just a lil more cash $210-ish
or the edelbrock performer EPS (2701)-more current design of "ol faithful"
for non fuss carbs x2 on a q-jet...just get an adapter.
Gleekr is offline   Reply With Quote
Old 04-07-2009, 10:53 AM   #6
big_al_71
big_al_71's Avatar
In my engine small block "400" I chosed to go with an Edelbrock Air Gap intake and an Holley HP650..I dont have the exact part numbers here in my office but I can give them to you tonight if you are interested on knowing.....
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
