Old 04-06-2009, 11:32 PM   #1
Dapper Dan
Dapper Dan's Avatar
shackle and hangers question
Hey guys, I have been trying to figure out how much drop I have on the rear of my truck, and what type. I am pretty clueless when it comes to suspensions. I will try to get pictures tomorrow, but was wondering if shackles and hangers go on the front of the leaf springs or the rear. Sorry if this is makes no sense or is a stupid question, however any help is appreciated.
Dapper Dan is offline   Reply With Quote
Old 04-07-2009, 12:25 AM   #2
sailed2japan
Jonny
sailed2japan's Avatar
Re: shackle and hangers question
The front should have a bolt straight through the eye to the mount and the rear should have the shackle and hanger.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 04-07-2009, 03:04 AM   #3
fast75
Go Hard or Go Home!
fast75's Avatar
is your drop kit already installed? or are you thinking of doing it?
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
fast75 is offline   Reply With Quote
Old 04-07-2009, 09:13 PM   #4
Dapper Dan
Dapper Dan's Avatar
Previous owner dropped the rear around 4" if I am measuring correctly. I just dropped the front 2" with new coils. I would like to go another 2" all around, but if I already have 4" with hangers I am not sure how to get two more in back. From what sailed2japan said it is hangers. How do you guys suggest to drop two more inches in the rear with what I have?
Old 04-07-2009, 09:38 PM   #5
flamingbig10
6.0 powered square
flamingbig10's Avatar
you can go with 2 1/2 drop spindles and remove a couple of leaf springs
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 04-07-2009, 09:56 PM   #6
f.monroe
f.monroe's Avatar
Shackles and hangers usually lower one 4 inches . The shackle attaches the rear of the spring to the rear hanger . The hanger part of the drop comes by replacing part the leaf spring attaches to in the front (hanger). The replacement hanger in modified to lower the front leaf mounting point so it lowers it 2 inches . The hanger is a 2 inch drop and the shackle lowers it 2 inches for a total of 4 inches of drop .
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 04-07-2009, 10:38 PM   #7
Dapper Dan
Dapper Dan's Avatar
Thanks for the info and patience! Now I think the P.O. may have removed some leaf springs and put in a hanger. Maybe? What do you think? Thanks again.
Old 04-07-2009, 10:41 PM   #8
flamingbig10
6.0 powered square
it looks like just the leaf springs were removed
Aaron
Old 04-07-2009, 10:43 PM   #9
flamingbig10
6.0 powered square
Aaron
Old 04-07-2009, 10:54 PM   #10
Strodder
Daring to be Different
Strodder's Avatar
A 4/6 drop consist of either front 2" front spindle drop, or lower A Arms, and 2" spring's. The rear you have to flip the axle to get a 6" drop. By flipping the axle means putting the axle above the springs. You loose clearance to the frame, so you also have to install a "C" notch in the frame so the axle won't hit the frame. Here's DJM's web site. It should show you what I'm talking about.
http://www.djmsuspension.com/applica...html#silverado
Dennis
Check out my 65/73 Cheap Build Thread.
http://www.67-72chevytrucks.com/vboa...d.php?t=327644
KUSTOM RIDES
FACE BOOK PAGE:
https://www.facebook.com/groups/291198124258863/
1965 C-10 Short Bed 350/700r4
2012 Silverado 1500 Crew Cab
2016 Honda Accord w/ 18" rims
2007 Honda Goldwing Trike w/ NAVI
2001 Yamaha Roadstar Indian look alike
"Life's journey is not to arrive at the grave safely
in a well preserved body, but rather to skid in sideways,
totally worn out, shouting "...WOW!...what an amazing ride!"
Live Life Passionately!!!
[/COLOR]
I AM WE TODD IT, I AM SOFA KING WE TODD IT
Strodder is offline   Reply With Quote
Old 04-08-2009, 07:10 PM   #11
slash crashley
lucky knuckles
slash crashley's Avatar
Question on topic:
...is it possible to run drop shackles with a flip kit?
slash crashley is offline   Reply With Quote
Old 04-08-2009, 07:50 PM   #12
Strodder
Strodder's Avatar
Flipping the axle will drop it 6". With the dropped shackle it will be another 2"s, and will probably hit the frame even with the notch. If you want to lower it that much put a full air bag job on it with a monster notch. You will have to cut the bed though. I've made many trucks lay frame, even with 22" wheels on them. All you need is $$$$$
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-08-2009, 11:25 PM   #13
slugish
Slugish
Ihave 4 i n shackles & hangers in rear > wasn't satisfied so Ihad my springs dearched another 2.5 - 3 in for a total of 6.5 - 7 drop in rear .
do not have c notch , however I had to remove the bump stops & brackets to have any spring travel at all . Its not true you absolutely have to c notch unless you are down 7 in or more or if you carry heavy loads & if you did you could always put some air bags between frame & springs . yes , c notch would be ideal but its not a necessity . with a 6 in drop & bump stop brackets removed you would have ample spring travel for most normal driving situations .
slugish is offline   Reply With Quote
Old 04-09-2009, 10:25 AM   #14
Strodder
Strodder's Avatar
I disagree. Any kind of load at all you would hit the frame on sharp bumps.
Dennis
KUSTOM RIDES
FACE BOOK PAGE:
[/COLOR]
Old 04-09-2009, 02:42 PM   #15
slash crashley
lucky knuckles
Talking
heh. as i was writing the above post, a voice popped into my head that said "there's no way around it, jus' bag it already".
unfortunately, i've gotta hold off on air for a bit. i'm trying to get a house before dec. 09. so for now at least it's got a nice static drop. when it comes time, i think i wanna raise the bed floor up a few inches instead of cutting up the box. i still want it to be able to function as a pick-up truck. even with the flip kit in the rear, i had 10 cement parking curbs in the back and it didn't even bump. (i was creeping and crawling tho.)
Old 04-09-2009, 05:57 PM   #16
slugish
Slugish
yea ,I agree strodder. hard bumps with a load more than likely unless suspension is real beefy
