Good News!!!
It RUNSSSS
as some of you know I have been doing a engine rebuild the last week. here are some specs 87 TBI block 70~sbc 400 heads Comp cams Mutha Thumpr cam Kit Flat top pistons 650 edelbrock carb long tubes 2200 stall Movie With open shorties Movie with long tubes and mufflers Now I had a few questions, idle is at about 750 and when I put into drive or while driving and come to a stop it wants to die. I don't have power brakes or any accessories. Is the timing off? Thanks and enjoy ![]() ![]()
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby Last edited by Wilson_; 04-07-2009 at 04:05 AM. |
Re: Good News!!!
congratulations on getting it going
70 SWB STEPSIDE 70 BLAZER 09 challenger |
"THE GREEN GOBLIN"
Re: Good News!!!
Sounds Like a chopy Cam
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Re: Good News!!!
Congrats on stat-up!!! With a big cam 750 may be too low in park/neutral. Have you tried turning it up 100 or so? fwiw...650 in drive is what I like to start at.
Re: Good News!!!
ok i will check that out. I need to get a friend over here to hold the brake while i check!
Northern California Group Met list: Cyclone, KCJones, TranzAm, extd56, hotrodhomi, mnky30, Rokcrln, Brad, JerryJones, Petey-pablo, 72Subby |
Re: Good News!!!
Bobby it sounds good,,,,
Congrats on getting it going.
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Re: Good News!!!
Thanks!
Re: Good News!!!
any luck gettin it dialed-in?
Re: Good News!!!
On a cam like that youll need to bump up the idle to about 900-1000rpm. Now as far as timing I always set mine by ear. Advance it till you hear it ping under a load then back it off till it stops and its always right on the money then.
A computer once beat me at chess, but it was no match for me at kick boxing. Duct tape is like the force. It has a light side, a dark side, and it holds the world together. |
#10 | |
Re: Good News!!!
ahhh ok cool, i havent really messed with it because i have not had the time. but hopefully this weekend i will be able to dial it in. thanks for the help
