One day.....
Question about oil pan
Is it possible to remove pan without lifting motor? Thanks.
DZL1. |
Between Trucks...
Re: Question about oil pan
No. The motor only has to go up enough to put some pieces of 2 x 4 between the motor mounts and stands.
Beat it to fit, Paint it to match... ![]() |
Active Member
Depends - I can remove stock or aftermarket oil pans off my Big block without jacking up the engine
You may have to spin the crank to get the crank arms on the front of the crank out of the way so you can clear them and pull the pan towards the back
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
"the other guy"
the key way on the crank needs to be pointing to 6oclock
God Said,"Building A 10 Second Import Is Like Coming Out Of The Closet, In The End Ur Still....."EXPLETIVE" ![]() |
One day.....
Thanks for all the input guys.
DZL1. |
