Old 04-07-2009, 01:08 PM   #1
maxreps
anyone ever replace front fenders and have this...
a problem with the rear of the hood not sitting flush. But the fenders are aligned with the doors, windshield pillars, etc... Already tried loosening the hinge bolts on each fender to adjust it with no luck. Not sure if I should try making the holes oblong so I can "push" the hinges down.
front parts is fine and it closes fine too
maxreps is offline   Reply With Quote
Old 04-07-2009, 01:21 PM   #2
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: anyone ever replace front fenders and have this...
Remove the springs and see if it will sit down, if it does the hinges may be worn. But making the adjustment holes longer may be a good fix for it.
I can't really say without looking at it.
Aftermarket fenders?
heavychevy79 is offline   Reply With Quote
Old 04-07-2009, 02:30 PM   #3
87Bob
If the hood fit fine before the fender change it has to be the mounting holes for the hinges in the fenders. I think you were spot on about elongating the holes. You didn't say how much you were high but I would guess it is around 1/4 inch. Try it it should not hurt anything.
My Truck's not leaking its marking its territory!
87Bob is offline   Reply With Quote
Old 04-07-2009, 06:10 PM   #4
jott_06
Camaro Club
jott_06's Avatar
Loosen the rear most hinge bolts enough that you can spin them with your finger then just barely loosen the front hinge bolts, Push up on the front of the hood so the back of the hinge rocks downward, Tighten bolts while holding pressure up on the hood. This method usually works as long as the hinges aren't worn to bad.
jott_06 is offline   Reply With Quote
Old 04-07-2009, 10:10 PM   #5
maxreps
The PO had just replaced them before I got it, not sure if they're chevy replacements or not though. The rear is about 1/2-5/8" high. I'll try removing springs to check for worn hinges and then the other adjustment technique.
thanks guys
Old 04-07-2009, 11:18 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Don't remove the springs. They are a ***** to get back on. If the hood fit before, then the problem is in the adjustment. If you rotate the hinge up in front, it should bring the back down.
Try it first before you elongate holes or remove the spring.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-07-2009, 11:35 PM   #7
bigblock73
yeller
bigblock73's Avatar
Somewhat off topic, but thought I would share a trick I learned about re-installing hood springs.
If you need to remove the springs for whatever reason, and will eventually have to reinstall them...yes, they can be a PITA!
Before you try to pry them off, do this.
1. Open hood enough to stretch the springs out...not all the way so they are completely compressed.
2. Grab your change jar...and start stuffing pennies/nickels, etc. between the spring coils.
3. Open the hood all the way, and the springs will literally fall out.
4. To reinstll them, keep the coins in there and reverse the steps above. Once you close the hood...the change will fall out all by itself.
If the springs are already off the truck, you can stick them in a vice and bend it and stick coins in as you do so...it will lengthen as each coin is inserted.
Sounds corny I suppose, but it works and you dont have to worry about flying springs, chipped paint, or injured body parts.
bigblock73 is offline   Reply With Quote
Old 04-08-2009, 08:16 AM   #8
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
now t his is an idea i never heard of and sounds like a great idea thanks!!
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 04-08-2009, 08:25 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Great idea Jeff. I'll start saving my pennies.
Articles-
"Refining Sierra"
