Prostreet 72
How dose this come off???
The nut is loose, but it just keeps on spinning. Is there a trick?
Prostreet 72 "Green Monster" 1972 Fleetside Build http://67-72chevytrucks.com/vboard/s...1&goto=newpost http://67-72chevytrucks.com/vboard/s...d.php?t=319041 |
Re: How dose this come off???
that little hole next to the key is a release for the lock cylinder,I don't remember exactly what had to happen but I think the key has to be in it and then slide a straight pin into the hole then turn or pull the lock cylinder out.anyway you get the idea,the nut wont come off past the cylinder cover so cylinder must first be removed....good luck
you have to pull the lock cylinder out first. You turn the key to the left and insert a paper clip or small Allen wrench in the small hole. push hard on the Allen wrench and turn key to left and pull out. May need to spray lube or graphite in the small hole
69 Chevy 4x4 383 Power ![]() |
69 Fleetside
![]() Join Date: Mar 2009
I will be trying to get mine back together tonight...I ran into the same problem you had and this forum was a huge help...I hope it goes back together easier than it came apart!!..
![]() Last edited by Beatcoaster; 04-07-2009 at 02:07 PM. |
#5 | |
Under Construction
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
it goes together real easy. i had to chuckle i started a thread like this when i tried to get mine out.
i think every single one of us has asked that question!
- Jason If you can turn, Youre not going fast enough. Favorite caption: first car to 200 mph in the 1/4 mile, no parachute, drum brakes all the way around.. ..back when men were men. |
Prostreet 72
I agree, this forum is worth every penny you spend on it. Thanks for the help guys. I'll give it a try tonight.
69 Fleetside
It does go back together pretty darn easy, just line all the tabs up correctly, screw the face back on, line up the pin hole with the tumbler and turn the switch with a screw driver if it has changed positions internally until it all aligns back up and push the tumbler back in(easily) with the key and turn it to acc/on/start so you know it all works again...took me 5 minutes to get it done
