Old 12-22-2002, 07:11 PM   #1
matt_field
matt_field's Avatar
anything i need to know about a automatic swap??(4x4)
hey, on my 67 it is now a 292 3 on the tree deal, coming real soon im pulling the engine, trans, transfercase, and column. i have everything i need for the swap. im putting in a 383 stroker, th350 and a np205 transfercase. will the bolts and everthing bolt up from the old tranny and transfercase? or will i have to end up drilling stuff. also im putting in a tilt column thanks alot guys..
matt
1971 k5 blazer 80k mike survivor
1972 3/4 ton 4wd Cummins 12v
1967 swb 2wd 427bbc
1968 4wd shortbox
1971 Cheyenne swb k10 unrestored
1971 Cheyenne super 40k 402bb survivor
1967 Chevy k10 (first truck)
1968 L78 camaro survivor 18k miles
1969 z28 survivor 60k miles
1969 z28 survivor 39k miles
1969 z28 rs survivor 80k miles
matt_field is offline   Reply With Quote
Old 12-22-2002, 11:16 PM   #2
Rod
The top parts off the frame for the engine mounts need to be changed,,... the 292 mounts are in different locations than necessary for the V8. The rockwell transfer case which is probably in your truck now will use u-joint type connections for the drive shafts... depending on the year your np205 is from you may have a need for different type mounts for affixing the drive shafts to the transfer case. If the NP is from between 70-75 you should be OK.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 12-22-2002, 11:20 PM   #3
breeh
Recovering 67-72 Addict
breeh's Avatar
Check the 4x4 board. This has been discussed there at least a couple of times.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 12-23-2002, 12:26 AM   #4
matt_field
matt_field's Avatar
i have a V8 crossmember, and the transfercase is out of a 72 gmc burb.
1967 swb 2wd 427bbc
1968 4wd shortbox
