04-07-2009, 02:11 PM | #1 |
It's Better With Nitro
Cowl Cold Air Intake - Factory Style Air Cleaner
I did a few searches here, but did not find it...I thought I had read a post awhile back from someone who used the removeable cowl access panel (passenger side firewall above the heater unit) for a cold air intake with ducting to a factory-style snorkel air cleaner housing. Does anyone have the link or photos to that modification? I think a snorkel-type air cleaner housing was used in this modification.
04-07-2009, 04:22 PM | #2 |
Its Deja Vu time again
Re: Cowl Cold Air Intake - Factory Style Air Cleaner
I've seen it done several times for Jeeps, but I don't have anything for these old rigs.
04-07-2009, 04:46 PM | #3 |
1961 crewcab
I think it might have been in alans classics' build thread, he was thinking of doing it, and several people commented on it.
04-07-2009, 10:46 PM | #4 |
60-66 Nut
I haven't seen what you're looking for, but I know what you're talking about. I don't think it would be too difficult to do. I guess it depends on your fab skills and eguipment.
04-07-2009, 11:02 PM | #5 |
that would be pretty cool.
I remember one guy on here had one of those expensive polished aluminum do-it-yourself CAI kits, but IIRC he had them aimed towards the snorkels on the front of the hood. |
04-07-2009, 11:17 PM | #6 |
That would be so cool (no pun intended) and good for a few HP.
The cowl through firewall fresh air intake is a very rare option on some early Camaro Z28's also (I have only seen one) If you can TIG or have access to someone that can, it easy to modify about any air cleaner and make this work with some large diameter flex hose that you flatten into an oval. I have modified air cleaners/relocated snorkels using MIG but it is a lot more work due to thinness of material and a lot of grinding of your welds. If you do it, post pics please.
292 + TKO500 |
04-07-2009, 11:41 PM | #7 |
1 thing at a time is progress.
We discussed it a little bit on page 16 of my build. I still haven't decided yet. Once I get to that point I'll give it more thought. It would be cool if done right. I don't know what right is yet.
Alan
Philippians 2:14-16 |
04-08-2009, 08:41 AM | #8 |
Thanks...yeah, I just fabbed a short piece of 2 1/2" x 6" oval tubing as an intake mouth piece for a friend. It was while I was doing more work to fill in the holes on my firewall on Sunday I thought the shape of the oval tubing would fit just right...I just need to find an air cleaner housing that I can hack up.
04-08-2009, 10:22 AM | #9 |
Airport Bum
Here is one from a Z-11
1964 Chevrolet C-10 1941 Chevrolet coupe 1962 Thunderbird 1959 Edsel Villager 1963 Skylark |
04-08-2009, 10:38 AM | #10 |
Jonny
That would look really trick under the hood of one of our truck. I just wounder whwere you could pu it and keep the heater.
1966 C30, Cummins, stacks, and a flat bed in progress... "Honor.....simply put, A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it." -AEC Hundley USNR |
04-08-2009, 01:45 PM | #11 |
I wonder if you could fab up something so its reversed some? Either that or you are more or less creating something from scratch.
04-08-2009, 03:03 PM | #12 |
I'll just fabricate something from scratch...it's a suitable air filter housing that has me on the hunt, now.
04-08-2009, 03:44 PM | #13 | |
Sunburst C10!!!
im not sure why they got rid of it, probably heat inside the cab
Gage 1967 C10 Shortbed Stepside Last edited by jgh64pkup; 04-08-2009 at 03:45 PM. |
04-08-2009, 04:12 PM | #14 | |
TexasBowhunter
Like this? http://www.knfilters.com/Racing/plenum.htm
Build in progress for son's first truck. |
04-08-2009, 05:19 PM | #15 | |
Just remember this. Note: The custom plenum is recommended for small displacement engines (less than 200 C.I.) or low revving V6-V8 engines. If the engine requires more than 45 sq. in. of filter area then the plenum should not be used because the carburetor would have to be re-jetted and a loss of high R.P.M. power will be the result. |
04-08-2009, 05:23 PM | #16 |
Not to hijack the thread but.... An original Z11 air cleaner is wort $40,000.00..... I know the guy who owns the original old reliable and a THREE other original Z11 cars... Here is a link to a few pics... if your ever near Dubois Pa get ain touch of him and go see his collection! Very nice man as well!
http://retrorides.proboards.com/inde...=19802&page=22
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
04-08-2009, 05:36 PM | #17 | |
04-08-2009, 09:39 PM | #18 | |
TexasBowhunter
