![]() Join Date: Jan 2009
No gauge lights!!!!
Driving home tonight and hit a bump and my headlights flashed off and came back on but my gauge lights went off and didn't come back on. Haven't been able to check it out yet. I messed with the dimmer switch, the voltage regulator and the plug going into the back of the dash but I couldn't get it to work.
Any Ideas at what it could be.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
its all about the +6 inches
Re: No gauge lights!!!!
do your brake lights/parking lights/dome light work... or did they all go out?
![]() Join Date: Sep 2007
I believe that your saying you messed with the plug to your dash/gages. I would look at your headlight switch plug, sounds like maybe it shook loose or has a little corrosion. Pull it off and back on a few times should solve your problem...
everything works except the gauge lights, even the gas gauge works
Son of a gun
it working and I looked forever for a cause. I replaced the headlight switch and they work fine now. The reostat that controls the brightness went bad.
Bill BEATERS ARE NEATER |
