Old 04-08-2009, 12:47 AM   #1
jimmywicked
jimmywicked's Avatar
Can I use 86 4x4 suspension on my 68 2wd
Can anyone help with this question? I have a 68 2wd long bed and after doing some quick measurements on the frame widths it looks like the entire suspension assembly will work if I reweld new spring mounts any one out there do any thing like this???
jimmywicked is offline   Reply With Quote
Old 04-08-2009, 11:27 AM   #2
Mudder
Mudder's Avatar
Re: Can I use 86 4x4 suspension on my 68 2wd
Yep it's been done. You will need a high hump to clear the TC. Steering will need to be used off of the 4x4 also. Do a lot of measuring then do some more.
Mudder is offline   Reply With Quote
Old 04-08-2009, 10:41 PM   #3
dgfreeze
i've created a monster
i have a 69 GMC lwb that was originally a 2wd. i stripped it down to the frame, and i mean the frame. i then installed the entire drivetrain off of an 81 K20. engine, tranny, transfer case, front axle and springs, rear axle and springs. i had to fabricate EVERY mount except the rear spring mount for the rear axle. this included the engine, tranny/transfer, both front spring mounts, the sway bar mount, and the front spring mount for the rear axle. it was a royal pain in the arse. not saying it wasn't worth it, but as mentioned above, you had better measure everything ten times, and write it all down. and keep posting on here. i would have saved myself a lot of headaches had i been a member at the time. but good luck
dgfreeze is offline   Reply With Quote
Old 04-08-2009, 10:44 PM   #4
dgfreeze
oh, and i just noticed, welcome to the board. you will love it here. incredible amount of knowledge in here.
Old 04-09-2009, 08:04 AM   #5
jimmywicked
Thank you for all your help I do appriciate it.
Old 04-09-2009, 08:29 AM   #6
Mudder
Mudder's Avatar
Do a little reading here. You may just want to swap bodies.
Old 04-09-2009, 04:18 PM   #7
jimmywicked
Thanks I was origanally going to swap bodies but the 73-87 has a kick up in the frame right under seat area and the 68 is flat. But if djfreeze is still reading, why couldn't you use the spring perches from donor vehicle.....it looks like if you knock the rivets out you should be able to remount on the 68 frame..once stripped of suspension of course and again just wondering I'm sure you have a better grasp on this than I do...I'll be out of town till after Easter so dont think I'm ignurnt if I dont reply till then.................
Old 04-13-2009, 01:56 PM   #8
dgfreeze
well, i could be wrong, but according to my memory, i do believe there were differences in frame width and height that made 3 of the 4 spring perches not usable. if you would like, i will be more than happy to email you pics of all the mounts i made, so you can see what i did. also, i honestly don't know, there may be differences in your 68 frame to my 69 frame. doesn't seem likely, though. but, if you do want pics, just send a private message with ur email.
