Old 04-08-2009, 12:50 AM   #1
88 Dippy
88 Dippy's Avatar
yay!!!!
I finally got the valve seals replaced it still smokes but not as bad as it did so i call this a success
The engine also feels like it has its balls back not that all the rockers are adjusted correctly some where too tight others to loose. And it has the correct fuel pressure for the edelbrock carb have it set at 5 psi.
The timing was also way to far retarded it was at -10* retarded so it was a gutless wonder i have new plugs, wires, cap, rotor, coil, and fuel filter
Sorry for the rambling but i am just happy to have the truck running vary well. Now i need to fix the tranny pan leak and rear seal thank got it's a 2 piece
1974 chevy Cheyenne C10 "The Mutt":4x4 convertion, NP208, 700-R4, stock 350, edelbrock Torker intake, edelbrock 600 CFM carb, duels
2001 Pontiac Grand Prix GT: 3.8L supercharged, 9.2:1 comprestion, ZZP XP cam, home made intake, 2 1/2" exhuast, 10psi of boost
88 Dippy is offline   Reply With Quote
Old 04-08-2009, 07:49 AM   #2
Cherub
Cherub's Avatar
Re: yay!!!!
sounds like a victory to me.
Cherub is offline   Reply With Quote
Old 04-08-2009, 08:07 AM   #3
85Bowtie
85Bowtie's Avatar
Re: yay!!!!
Sounds good. You notice any better mpg?
Don't you miss your Mopar now? Not having to adjust the rockers is great.
'69 Dodge Charger R/T 440, 727, 3.55 Sure Grip
'68 Plymouth Road Runner 383, 727, 3.23 Sure Grip
'89 Dodge Diplomat ex cop car 408, 727, 3.55 Sure Grip
'77 Dodge Monaco ex cop car 440, 727, 2.71
'79 Dodge 'Lil Red Express pickup 360, 727, 3.55 Sure Grip
'12 Dodge Challenger SRT8 392, M6, 3.92
'85 Chevrolet C-10 SWB 2wd 305, TH350, 2.73
85Bowtie is offline   Reply With Quote
Old 04-08-2009, 08:28 AM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: yay!!!!
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 04-08-2009, 09:38 AM   #5
88 Dippy
88 Dippy's Avatar
Re: yay!!!!
i didn't drive it varry far to see if it is getting better milage but i think it is goingto i do not have to have my foot in it as mutch. i realy do need a diffrent intake though the "torker" just does not have any "tork" down low to move this beast. thinking of getting a performer or performer EPS
ya i miss the diplomat i did the day it left but it needed way to mutch frame and body work
Old 04-08-2009, 09:43 AM   #6
85Bowtie
85Bowtie's Avatar
Re: yay!!!!
You have a torker on it?
yeah you need a dual plane intake on that thing.
Torkers are usually for cars that already make alot of torque down low and are looking to get more HP higher in the rpm band.
That's the intake I have on the R/T
Old 04-08-2009, 11:50 AM   #7
OrangeAnimal
OrangeAnimal's Avatar
Re: yay!!!!
Get the performer eps!! I have one and it is way better than the standard performer. You have to remember the performer design has been around for longer than a can remember. The EPS has smoother bends inn the runners and it looks like the runners are alittle bigger. I replaced the Performer on my 82 with the EPS due to the performer had been repaired for cracks in the exhaust recirculation ports. The newer design seems to have a slightly different design in that area as well.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold
93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs.
09 Yaris wife's daily.
OrangeAnimal is offline   Reply With Quote
Old 04-08-2009, 02:15 PM   #8
heavychevy79
Cheyenne Super
heavychevy79's Avatar
Re: yay!!!!
Car craft did a test on those and the Torker didn't gain much at all at top end over the EPS, and lost quite a bit of HP to the EPS for the average.
And this was on a built engine, not a stock one.
heavychevy79 is offline   Reply With Quote
Old 04-08-2009, 06:10 PM   #9
88 Dippy
88 Dippy's Avatar
Re: yay!!!!
well then i will save up some money and do that. i rember looking at the engine going "why does this fairly stock mid seventies truck have a low rise single plain manifold?" then i try to punch it from a stop and going "why can't this mid seventies truck with a V8 and 4:10 gears and open diff break them loose?"
i think it is the intake. might even be the 882 smog heads that are on it as well
