Rear shock relocation position ???
Hi, Can anyone show me a picture of a rear suspension with shock absorbers that have been relocated,
63 C10 longbed, Thanks Darron |
Old Skool Club
![]() Join Date: Jun 2001
Re: Rear shock relocaion position ???
I would if it wasn't dark and rainy. I have used Early Classic Enterprises shock relocators on my '69, which is lowered 4-inches with coil springs. It also has an adjustable panhard rod (track bar). Another member may have a picture before I can post one.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
Resistance is Futile
Re: Rear shock relocation position ???
......here you can see the lower relocation bracket. I never installed the tops..got lazy
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
#4 | |||
Union Electrician
The upper bracket is hard to see, but you can tell the difference in the angle of the shock when compared to the one posted above.
![]() ![]() Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
GM ONLY BABY!!!
I put my relocators on my 72 and the shock doesn't line up properly. The bottom bolt wants to go in crooked. Anyone else have this problem? Sorry not trying to hijack, just have a similar question.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride ![]() ![]() http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
#6 | |
Hi, Yes shock bolt holes and angle seem th bee the problem, I have ordered 5" drop coil springs, ? What is your setup, i see u have lowering blocks, I have to make waht brackets myself as postage from the us to the uk is very high, (just ordered a power brake booster from brothers $299 for the booster & $285 for the shipping ?????, Thanks Darron |
