Rear end width on '94 2wd 1/2 ton?
Hi there, I've got a '94 Chevy 1500...I'm in the process of putting in a 425 Olds BB and a TH400, and am trying to figure out what rear end I want to use. My question is (since the truck isn't here at the moment) how wide is the rear dif.? I've got a few choices for a rear dif, 2 9inches, and a few Olds rear ends.
Thanks for the help, Bobby |
Old Skool Club
![]() Join Date: Jun 2001
Re: Rear end width on '94 2wd 1/2 ton?
TTT
Anybody got an answer?
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
If I remember correctly, my 90 454SS had a 65" hub width (drum surface to drum surface where the wheel hits).
Cool, I think one of my Olds rears will work out then....Now I just gotta find a tape measure
With a torch and a welder everything is universal fit... Measure with yard stick, mark with chalk, cut with torch...the 3 steps to perfection. |
