Old 04-08-2009, 10:27 AM   #1
ChopperDr
Lifting points?
I guess I might as well pull the motor and trans out to get the firewall cleaned up. Where are the best points to grab to pull them out together?
Chops
ChopperDr is offline   Reply With Quote
Old 04-08-2009, 11:14 AM   #2
sailed2japan
Jonny
sailed2japan's Avatar
Re: Lifting points?
When I pulled mine I bolted the chain thru the intake manifold bolt holes and into the head in all 4 corners. I also used an engine balancer, which I highly recommend.
1966 C30, Cummins, stacks, and a flat bed in progress...
"Honor.....simply put,
A veteran - whether active duty, retired, national guard or reserve is someone who, at one time in his life, wrote a blank check made payable to 'The United States of America', for an amount of 'up to and including his life.' That is Honor, and there are way too many people in this country who no longer understand it."
-AEC Hundley USNR
sailed2japan is offline   Reply With Quote
Old 04-08-2009, 12:03 PM   #3
MacAttack
283 Drama Queen
MacAttack's Avatar
Re: Lifting points?
Same here - and the balancer/screw is the way to go for sure.
For about 12 years of my adult life I had a severe speech impediment.
My ex-wife never let me get a word in edgewise.
MacAttack is offline   Reply With Quote
Old 04-08-2009, 02:56 PM   #4
daverod
SSN 706
daverod's Avatar
Re: Lifting points?
I pulled my (283) and 4 speed with the last two bolts on the manifold. With all the sheetmetal out of the way it came out easy. I'm sure four bolts and a balancer would be better. It was the first engine I ever pulled and I really had no idea what I was doing. But hay, the bolts held and it's out
daverod is offline   Reply With Quote
Old 04-08-2009, 03:47 PM   #5
sailed2japan
Jonny
Re: Lifting points?
Well 2 bolts is beter than bailing wire!
-AEC Hundley USNR
