Old 04-08-2009, 02:11 PM   #1
cornbread67
Alternator Mounting Problem
Im sure someone else has had the same problem I am having. I got a set of heads with no accessory holes without thinking and now I got to find a new way to mount my alternator without having to give up my power steering pump. Any help ?
cornbread67 is offline   Reply With Quote
Old 04-08-2009, 02:24 PM   #2
monte0185
monte0185's Avatar
Re: Alternator Mounting Problem
Look at summit for mounting brackets that fits on the bottom of the passenger side. It uses the bolt holes beside the water pump. You could also remote mount it to your driveshaft!! Ok maybe the second one is out there but its doable. Good luck.
A computer once beat me at chess, but it was no match for me at kick boxing.
Duct tape is like the force. It has a light side, a dark side, and it holds the world together.
monte0185 is offline   Reply With Quote
Old 04-08-2009, 04:57 PM   #3
truckintexas
There is a gm alt bracket (lower) that bolts to the motor mount and the water pump. I probably have one. PM me if interested.
truckintexas is offline   Reply With Quote
Old 04-08-2009, 08:17 PM   #4
centsless
sufficiently talented fool
centsless's Avatar
I have a set of Alan Grove brackets that were on mine. It uses the WP and front intake bolt. PM me if you are interested and I will put pics and prices on the Sale forum.
"it's impossible to be surrounded by idiots when you are part of the circle"
2003 Suburban
2002 Pontiac Montana
1981 Corvette
1966 Impala Convertible
Click here to support the board
centsless is offline   Reply With Quote
