Old 04-08-2009, 07:04 PM   #1
LinkbeltOE
Bed Wood
Hey guys,
I am in the middle of restoring my long bed stepside wood and noticed the width of my bed wood is not the same, I want to make all the boards the same width and add another strip so all boards are about 5" wide. What I was wondering is has anyone done this and if so how does it look? Any help would be appreciated. The 2 end boards are about 2" wide then 4 boards are just under 8" and 2 boards are about 6". I have some really really nice Brazillian Walnut 1" X 6" and want to use it, what do ya think?
LinkbeltOE is offline   Reply With Quote
Old 04-08-2009, 08:42 PM   #2
TheDark1
Intentionally Left Blank
TheDark1's Avatar
Re: Bed Wood
I haven't ever done it, but I don't see why it can't be done. You'll have to redrill all the holes I'm sure. You might want to use some pine or plywood as a template. It's relatively cheap and you'd get an idea of how the pieces would fit. Sounds like a nice project, though.
1965 C-10 Short Fleet 468/TKO 5-Speed
2004 2500HD Crew 496/Ally Blacked Out (SOLD!!)
1997 Formula WS6
2004 Jeep Wrangler (Sold)
2013 Jeep Wrangler (Sold)
2017 Jeep Wrangler (Blacked Out on 35's)
2011 GMC D-Max Dually Denali 3500HD (Sold)
2015 GMC D-Max Dually Denali 3500HD (Sold)
2018 GMC D-Max Dually Denali 3500HD (Sold)
2020 D-Max Dually Denali on 33x12.50's
1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles
TheDark1 is offline   Reply With Quote
Old 04-08-2009, 09:21 PM   #3
jason65
Registerd User
jason65's Avatar
Re: Bed Wood
www.Mar-k.com has some good instructions on it.
jason65 is offline   Reply With Quote
Old 04-09-2009, 06:58 AM   #4
doubledog
doubledog's Avatar
Re: Bed Wood
i just finished mine a couple of days ago,but i went with the kit from classic parts,for the money around 500$ and all the stainless you cant beat it i dont think,just my two cents.here is a couple of pics,i just posted in another thread. this is yellow pine it runs a little cheaper than the oak does .
doubledog is offline   Reply With Quote
Old 04-09-2009, 07:23 AM   #5
jason65
Registerd User
jason65's Avatar
Re: Bed Wood
Doubledog, did you have to drill the outside edges where the wood meets the edges of the bed or did it come all predrilled?
Old 04-10-2009, 10:05 AM   #6
doubledog
doubledog's Avatar
Re: Bed Wood
the holes on the out side edge have to be drilled by yourself but the rest were predrilled but they charge you a extra 30$ for drilling but it is worth the money as you can see every thing fits real nice.i put some stainless strips over the top of the existing rails attached to the bedsides a few of the holes were rusted a little bit.
Old 04-10-2009, 12:07 PM   #7
502tripower
502tripower's Avatar
Re: Bed Wood
Originally Posted by LinkbeltOE View Post
Hey guys,
I have made several bed wood kits both stock and custom. If your material is not wide enough you can do a tung and grove joint and glue two pices together to get the desired dimension or do a bisquet joint. I prefer the tung and grove. Once the glue is set then resurface your material to 3/4". Here is a link to the dimentions you need. Good Luck
http://www.gmcpauls.com/47-72_BedWood_Info.htm
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi
1961 Impala SS 348/350 4-speed 3:70 Posi
1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed
1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear
1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc
1949 Transitier 3-wheel forklift Crosley 4-Banger
98' FXD
2002 2500HD
502tripower is offline   Reply With Quote
Old 04-10-2009, 12:20 PM   #8
apachedaddy
apachedaddy's Avatar
Re: Bed Wood
I think what he was asking was missed. Yes you can do it with the equal width boards. You will just have to drill some new holes in your cross sills and add another strip. That will get the look your asking about. I did it that way with some wood i had floating around to get a floor in it. But i did go with a kit from MAR-K when i re-did the bed because it needed all new cross sill's and didn't want to drill more holes in the new ones.
apachedaddy is offline   Reply With Quote
Old 04-10-2009, 12:41 PM   #9
502tripower
Re: Bed Wood
I think we got what he was asking but the problem with making the boards all the same width is he will be adding bed strips and I don't know if you can just buy the bed strips one by one? I think they are sold as a kit? I think the reason he was asking if he could make all the boards the same width is his material was not wide enough?
98' FXD
2002 2500HD
Old 04-10-2009, 08:47 PM   #10
LinkbeltOE
Re: Bed Wood
apachedaddy, & 502tripower you are both right. I know I have to drill new holes and buy another strip and yes they sell the strips separately and in a kit, what I was asking is, 1.If anyone had done it? And B. if anyone had pics and knew if there poses a problem? Also what ya'll thought of the hard, hard wood I chose for the bed. If I knew how to send a pic in here I'd post it. It is sweet.
Old 04-10-2009, 08:49 PM   #11
LinkbeltOE
Re: Bed Wood
502tripower,
That would be a great website if I were to go with original wood widths,Thank you for it tho.
Old 04-12-2009, 03:30 PM   #12
LinkbeltOE
Re: Bed Wood
Anyone else?
Old 04-16-2009, 01:25 PM   #13
LinkbeltOE
Re: Bed Wood
Well I got the wood milled down to ORIGINAL spec,I didn't go with all the boards being uniform due to just didn't want to drill all those holes. If I knew how to put pics up here I would and if anyone could help me out that would be great.
Old 04-16-2009, 01:35 PM   #14
joe231
joe231's Avatar
Re: Bed Wood
http://67-72chevytrucks.com/vboard/s...d.php?t=295313
http://67-72chevytrucks.com/vboard/s...d.php?t=209103
http://67-72chevytrucks.com/vboard/s...d.php?t=201224
CHEVY ONLY
Old 04-19-2009, 08:07 AM   #15
LinkbeltOE
Re: Bed Wood
How do I resize them?
Old 04-19-2009, 08:20 AM   #16
LILRED66
LILRED66's Avatar
Re: Bed Wood
On your computer, go to Windows Explorer and find where you keep your pictures stored on your computer. Double click on the photo you want to post. On the bottom right side of the screen showing the photo, there is an icon for resizing a photo and the prompt will ask if you want to close this application and open the photo for resizing. It will then pull up the photo and you can drag the borders in a bit to decrease the width or height. After doing so, you can save the photo under "save as" and name it whatever you want so you can find it later. After you have done this you go to the forums and hit the Go Advanced icon. The screen will refresh and there will be a paperclip in the icon choices. Click on the paper clip icon and a browse window will appear. Click the top browse icon and it will direct you to the various locations of your photo locations. Find the photo you resized and double-click on it and the file name of the photo will appear on the title line next to the browse icon. Click on upload photo and if all was done properly, the photo will now be on the thread you are creating. If it doesn't work, call me and I will talk you through the process. Once you do it, you will get the hang of it and have a lot more enjoyment with the site. Good luck and let me know if I can help.
LILRED66 is offline   Reply With Quote
Old 04-19-2009, 08:22 AM   #17
LinkbeltOE
Re: Bed Wood
http://yfrog.com/b7p1040061j I went with stock.
Old 04-19-2009, 08:33 AM   #18
LILRED66
LILRED66's Avatar
Re: Bed Wood
The width of the boards in the bed, stepside or fleetside, is only limited by your imagination. Make sure when laying out the widths, the wear strips do not land on the locations of the bed-to-frame bolt locations. These locations correspond with the factory landing locations of the cross sills and the factory stand-offs on the frame to accept the cross sills. The reason the boards are various widths is to avoid this problem.
The overall integrity of the bed/wood/cross sill/wear strip assembly is maximized by the number of fasteners through the wear strips and the perimeter flange at the bed sides & wheel tubs, plus the fact that they are backed-up underneath with the perpendicular cross sills and this sub-assembly securely attaches in serveral locations to the stand-ups on the frame. Eliminating the wear strips reduces the number of fasteners holding the entire assembly together, but I don't think it would compromise the assembly structurally.
I know you decided to move forward with the factory assembly method, so this information may not be much help, but I wanted to share anyway. Good luck and hopefully you can post some pictures of the process.
Old 04-19-2009, 08:45 AM   #19
LinkbeltOE
Re: Bed Wood
Did my link to a pic work?
Old 04-19-2009, 09:56 AM   #20
msgross
msgross's Avatar
Re: Bed Wood
I've got NOS bed wood for sale in the 67-72 parts board..
I might go with walnut..
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 04-19-2009, 02:47 PM   #21
joe231
joe231's Avatar
Re: Bed Wood
this one?
yeah it worked
CHEVY ONLY
Old 04-19-2009, 03:13 PM   #22
LinkbeltOE
Re: Bed Wood
OH geez thats huge.........yeah you need to resize that.
Old 04-19-2009, 03:14 PM   #23
joe231
joe231's Avatar
Re: Bed Wood
yeah sorry....I just linked it to your pic...didn't realize it was so big
CHEVY ONLY
Old 04-19-2009, 04:28 PM   #24
Mad Max
Re: Bed Wood
I think you should just sell the box to me and go with a fleetside instead !
(yeah I know....fat chance)
Mad Max is offline   Reply With Quote
Old 05-06-2009, 10:35 AM   #25
Tomb23
Re: Bed Wood
Has anyone installed Bedwood With out drilling though the 2 boards with the offset washers? Is there an alternate way ?
Tomb23 is offline   Reply With Quote
