Old 04-08-2009, 08:02 PM   #1
fastcam1
Young gun
fastcam1's Avatar
sway bar brackets
when using airbags are you supposed to use stock or lowered brackets? thanks
fastcam1 is offline   Reply With Quote
Old 04-08-2009, 08:10 PM   #2
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: sway bar brackets
you can either run the dropped brackets or mount directly to the frame.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 04-09-2009, 08:15 AM   #3
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I've even seem some people use the stock brackets and then mount the bushings on the inside of the bracket. If it were me I would pick up a set of lowered brackets and run those. And if you didn't want to do that, then I would mount the bushings directly to the frame.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
