So here is my problem... There is a smoking deal on a set of drop spindles, 4" blocks, shocks and a bolt in c notch off of a 93 S10 on craigslist.... I have a 98 S10 chassis that I am throwing under a 54 GMC I am buying this weekend... When I look at S10 drop spindles from MOST companys they list a part number for up to 94 and a different part number for 95 to 03 Except summit who shows their brand of spindle fits 84 to 03... Does anyone know the difference? Is it as easy as changing the ball joints or tie rod ends to make them work??? Why is summit different??? I even called Bell Tech and confirmed that their spindles are different.... HELP!!! Thanks!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
#2 | |
Re: I need S10 drop spindle help... 93 vs 98...
Thanks Scoti.... I thought you would respond to this... I am going to roll the dice and buy them... If they don't fit I will throw them on ebay..
I just called him to verify the exact year of his truck & it's a 99 model. I know the spindles were used on various Malibus (78-81) & a 93 Blazer I owned.
The spindle nut is a metric thread on the newer spindles. I just bought a set of castle nuts with the right thread. I tried to get a hold of belltech in jan, but the whole place was shut down for inventory. Summit told me there was no difference. He was sooooo much help!
I can still count my vehicles on two... wait three hands. |
Blazers are different. They switched to a duel piston caliper in '98.
Right..... Blazers utilize the different spindle that uses the dual piston LS style caliper. There are dropped spindles offered for these applications as well (& LS1/C% vette brake adapter kits).
Resistance is Futile
Wow!!!! I didnt know this, although it doesnt surprise me. I picked up some drop spindles and was going to convert to the S10 set-up with single puck calipers.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Look for post-98 S-10 Blazers for the right spindles & stuff. These use the separate rotor/bearing & hub assembly vs. the old school 1pc rotors so bearings are more expensive.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 04-09-2009 at 07:24 PM. |
#10 | |
Who makes a dropped spindle for this application?? Or do people just convert as I was thinking.....there are a million wrecked S10's ![]()
#11 | |
Thanx Scoti....just went to the Belltech site and read the install. Those spindles are righteous bucks. I just bought spindles, coils, shocks, blocks, leaf springs, and a front air-ride set-up for S10's for 200 bucks
![]() .....back to you c10addict!!!!!!!
#13 | |
#14 |
I saw your post on Dinos thread (totally hijacking now
#15 |
Yep, that would have been me & N2Billet. I was the guy w/the long hair.....
#16 |
Thanks for your help guys... Picked the stuff up last night... Brand new never installed spindles, 2 sets of 4" blocks, 4 drop shocks and a bolt in notch for $160.00... I love Craigslist...
