04-08-2009, 09:43 PM | #1 |
Need spider gears!!!!!!
Hi
Got a new project a 61 chevy K 15 4x4 its in decent shape for a midwest truck cab floor is completely intact! bed floor not so much , but oh well. Factory V-8, SM-420 4 speed T-221 transfer case still operates! here is my problem I am doing a quickie rebuild , engine , lookin things over fixin what needs fixed for a daily driver nothing fancy just so it all works and works right. It has an H033 rear axle I drained the fluid and water out so I felt I should pull it out and bottom line is I need spider gears . Where can I get these ? any help greatly appreciated. Thanks Bill |
04-09-2009, 12:20 AM | #2 |
60-66 Nut
Re: Need spider gears!!!!!!
You might try contacting the OP in this thread......looks like he isn't going to be using his '62 rear diff. I believe the 2wd are the same as 4x4's
http://www.67-72chevytrucks.com/vboa...d.php?t=337504
