Old 04-08-2009, 09:44 PM   #1
ceruzziracing
A/C compressor for air bags?
I vaugely remember reading something a while back about using an a/c compressor for your air bag set-up. My donor motor came with a compressore that amazingly isn't frozen up. Don't plan on installing a/c in my '62 but do plan on airbags front and rear. Has anybody done or know how to do this conversion and if it actually works? Figured it would save a fair amount of coin if I can utilize that instead of spending big bucks on a purpose built compressor...
ceruzziracing is offline   Reply With Quote
Old 04-08-2009, 09:50 PM   #2
TylerHuff
TylerHuff's Avatar
Re: A/C compressor for air bags?
people use york 209, 210 and sanden 550? i believe for air installs im not sure if all compressors put out enough psi. I have a york 210 but i still need to install it. Thats what most people use
1987 Gmc sierra
1962 Apache 10
TylerHuff is offline   Reply With Quote
Old 04-08-2009, 10:15 PM   #3
joe231
joe231's Avatar
do a search for york on here...lots of info
CHEVY ONLY
Old 04-09-2009, 12:06 AM   #4
protrash64
Resistance is Futile
protrash64's Avatar
I had a buddy that was into offroad 4x4 stuff and he said that people used the a/c compressors to air up their tires after being on the trail. It may be possible to do for bags.
I thought that refridgerant also lubed the compressor...not sure how that would work with bags.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 04-09-2009, 08:04 AM   #5
joe231
joe231's Avatar
that is why a york is usually the best choice. it has an oil reservoir.
CHEVY ONLY
Old 04-09-2009, 08:26 AM   #6
ceruzziracing
I had forgotten about the compressor needing lubrication, brain fart. I'll have to do some internet surfing and see what pops up. Might be way to filter the line going from compressor ....
Old 04-09-2009, 11:30 AM   #7
kizer
Its Deja Vu time again
kizer's Avatar
Since I started this FAQ I might as well Pimp it some.
http://67-72chevytrucks.com/vboard/s...d.php?t=331566
You can use an oil filter and then use a return line to pump the oil back into the York if you are using a york. If you are using a saden type of compressor you can dump aproximately a teaspoon of oil in the compressor now and then, but you will still need a filter to collect the oil.
Now the filter isn't one of those water filters you'd pickup from Home Depot. Its a fancier one that is designed to catch oil and probably will set you back around 35bucks.
Like I said in that thread I'm by far not an expert, but I've done a bit of research and know several guys running them. The York is the power horse, but the sauden will get the job done very well and most Jeeps come with the Sauden as a factory a/c compressor and they just adapt and make it work.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 04-09-2009, 04:47 PM   #8
ceruzziracing
Kizer, that is a great link, just what I was looking for! The 350 I got had the compressor as well as two air pumps attached (wonderful smog stuff ).
Old 04-09-2009, 06:01 PM   #9
kizer
kizer's Avatar
Hey no problem. I was going to edit the post with some more thoughts, but for some reason I don't seem to be able to edit my posts anymore.
Old 04-09-2009, 09:50 PM   #10
Fred T
Cantankerous Geezer
Fred T's Avatar
You can, but you have to do it within a few minutes of posting. Here's an explanation.
http://67-72chevytrucks.com/vboard/s...d.php?t=282195
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 04-10-2009, 01:40 AM   #11
kizer
kizer's Avatar
Ah, thanks Fred I at first thought I personally did something wrong until you posted that URL.
