Old 04-08-2009, 09:50 PM   #1
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
HEI wires
I need to hook up my HEI and can't find the diagram for the wire connections.
I have only one wire to connect from the engine harness but there are 3 on the
skip white unit- RED BLACK and YELLOW.
Anyone know what the wires do?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 04-08-2009, 09:51 PM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: HEI wires
Are those the wires that plug into the cap?
low'n slow is offline   Reply With Quote
Old 04-08-2009, 10:14 PM   #3
Sport/Truck
Sierra Grande Club
Re: HEI wires
No, they come out of the bottom of the dizzy. I didn't even look at the cap real close. I know it has the coil but you have me thinking....
s/t
Old 04-08-2009, 11:23 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: HEI wires
it plugs into the cap, right behind the coil/tach plugs
Old 04-09-2009, 06:59 AM   #5
Sport/Truck
Sierra Grande Club
Lightbulb Re: HEI wires
Man to I feel stupid I had remembered seeing something that said what the connections were for, and after Low'n Slow asked his question got me thinking that those plugged in the cap. When I went out to look at the cap it was self explanatory
I ordered the dizzy back in February 08 and haven't touched it since.
Thanks for the clarification.
s/t
Old 04-09-2009, 07:50 AM   #6
fatboys69
fatboys69's Avatar
Re: HEI wires
you will also need a 12v supply from the battery to the terminal that is right in front of that plug, look at the top of the cap ( plastic cover ) and it should be marked tach / battery. Have to do this or you will not get power to the coil so it will fire and run
fatboys69 is offline   Reply With Quote
