04-08-2009, 10:14 PM | #1 |
Help With Z'd Frame or Crossmember
alright so I'm looking to get my long box to lay rocker, it's bagged already..now I dont have the time/space or really weld skills to do get it to lay rocker so I'm going to take it to my friends shop, but I have a few questions...want to get as much info before I drop it off at the shop
-Whats better Zing the frame 4'' or notching the exsiting crossmember 1.5''? and why? -What problems or disadvantages or anything will occur with doing either of these and how will I fix or prevent these problems if there is any? -How long will each take rough estimate? because he charges by the hour.. -Or whats an idea on a cost a shop would charge for this with the trans tunnel and everything...truck has a 305 motor in it, not sure if he'll have to do any modifying or raising to make sure the hood will shut thanks!
After Thought Video Mid-West Show Coverage http://www.MyspaceImageCodes.net/images/76354Sig.jpg |
04-08-2009, 11:54 PM | #2 |
Happy to be here
Re: Help With Z'd Frame or Crossmember
Before I answer your long list of questions, have you consider the Dropmember?
That would be my first choice.
04-09-2009, 07:52 AM | #3 |
yeah..costs too much
04-09-2009, 08:06 AM | #4 |
The frame z will cost alot too. Lots of stuff gets moved up. The truck will handle better with a raised crossmember or dropmember.
In order to z the frame correctly you will need to remove the engine and trans. The core support has to be removed and the steering shaft has to be redone. The crossmember for the trans has to be redone. There also maybe some firewall to cut. I am sure there are more things to do but that is what I can remember. I think that if a shop was to correctly z the frame it would cost quite a bit. I would estimate the time to do it at no less than 10 hours. Honestly after looking at how my buddy did his I would never z a frame. Even if you do a killer job it just doesn't look right. I think cost wise you are better off with the dropmember. Even if you are alittle short now it's worth it to save and wait. Everyone I have ever talked to has loved the dropmember. I haven't heard the same about the frame z. I was over at my buddies last weekend and he is redoing the z on his due to cracks!
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold 93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs. 09 Yaris wife's daily. |
04-09-2009, 08:24 AM | #5 |
i agree with the dropmember being a better option, and you have 2 companys to choose from... but in the end it's what you like best, hopes it goes well ither way...
My truck spends more than my wife, is that normal? |
04-09-2009, 09:57 AM | #6 | |
how many hours does it take to install that? do you still need to cut a trans tunnell? also someone told me you'd still need to do a stock floor body drop to get it to lay rocker? I've also heard the option other than the Z is notching your stock crossmember..how do you guys feel about that? any info would be great thanks!
04-09-2009, 11:00 AM | #7 | |
if you already have spindles, then you could go with ***************** or porterbuilt crossmembers and they are both good options. i can't help you a lot because i haven't bought or installed one yet, but its in my to do list. here are several websites where you can find information about both crossmembers. porterbuilt: http://www.c10forum.com/forum/forumdisplay.php?f=69 http://www.c10forum.com/forum/showthread.php?t=566 http://www.c10forum.com/forum/showthread.php?t=611 *****************: http://www.c10forum.com/forum/forumdisplay.php?f=17 http://www.c10forum.com/forum/showthread.php?t=73 http://www.c10forum.com/forum/showthread.php?t=569 http://www.c10forum.com/forum/showthread.php?t=699 hope this helps...
04-09-2009, 02:19 PM | #8 |
thanks for the info appreciate it!
anyone install one? picts please and info on how long it took and what all you needed to do.. also anyone try just notching the stock crossmember like 1.5'' or so?
04-09-2009, 02:41 PM | #9 |
nickle and dime |
04-09-2009, 02:49 PM | #10 |
not sure if mentioned this but I will be hauling a small camper 17' it's pretty light maybe less than 2,000 lbs..some people say I'll problems towing with a Z or notched crossmember...is that true? what if I went with the dropmember would I still have problems...the camper will only be towed 5 times a year to shows out of state anywhere from 2-9hrs away
04-09-2009, 06:39 PM | #11 |
Double 6's
IMO, go with a crossmember. Towing could cause stress on the notched x member, or the z'd frame. I Z'd mine, but I am not towing anything, and the shop owed me money, or I woulda done a new crossmember. Its the way to go. either way the engine and trans must come out. The X members center your wheel and narrow the track if I remember correctly, and if you want to rocker the truck a bodydrop is in your future, traditional or stock floor. Keep in mind if you Z it, trans and driveshaft tunnel will need to be done, I think, and the same with either type of bodydrop. Gurus, correct me if I am wrong, thanx!
Street Glidin! 1966 LWB Custom Cab (sold) 1982 Short Fleet (under the knife) 1998 S10 2wd Fleet 2007 Chevy Silverado Crew 2007 Harley Davidson Street Glide |
04-09-2009, 07:13 PM | #12 |
Now knowing that you want to tow with the truck I would go with the dropmember. I just wouldn't trust the z'd frame for that duty.
04-09-2009, 09:08 PM | #13 |
c10 Chop Artist
It's incorrect that you have to remove the engine to do a frame Z. I have done quite a few without removing the engine or trans incl. a few toyotas and some c10s. You will have to make a new trans x member though.
04-09-2009, 09:42 PM | #14 |
any picts of a 73-87 with the dropmember? I want to see how much it lays out...maybe it'll be good enough for me and I wont need to do a body drop
can you just do a stock floor body drop without the dropmember or Z?
04-09-2009, 11:38 PM | #15 |
67-72 parts collector,…
Look at this bad a$$ '77 laying out on 22's. And it's all Dropmember.
http://67-72chevytrucks.com/vboard/s...d.php?t=317834.
04-10-2009, 12:14 AM | #16 |
Happy to be here
Now that your here in this forum look around a bit. There are several threads discussing all your questions at length Follow the links that have been posted for a plethora of information.
04-10-2009, 08:54 PM | #17 |
Double 6's
Yep! My bad, Now that I think about it, the guy that did mine didnt pull the motor. Sorry bout that!
04-10-2009, 08:58 PM | #18 |
wouldnt it help/be easy to pull the motor?
04-10-2009, 11:08 PM | #19 |
c10 Chop Artist
It is a little easier but not neccessary. With the proper use of jackstands and a good floor jack you don't have to pull the engine/trans and could easily get it done in a weekend and drive it to work on monday.
04-11-2009, 07:27 PM | #20 |
I think badblu97 was smoking crack or something... lol. J/K derek.. you know I'm just kidding. By the way derek I can see how you forgot that... after all you are crazy.
04-11-2009, 11:50 PM | #21 |
Frame Z starts at about $1500 in labor at my shop. That's roughly 24 hours of billed time. A crossmember costs less than that. But by the time you get the other parts and have it installed, it will be more. But the crossmember is going to be problem free with just about anyone installing it. A frame Z could go badly in the wrong hands. I've seen it happen, and I've fixed my fair share. So I would also vote for the crossmember. It's a well designed system that's proven to work.
Also, you only need about a 2" Z to lay out. 4" is pretty excessive.
If you can find it cheaper, I can fix it! |
