It followed me home?
How much damage can dragging LCA's really cause?
Just curious what problems you all have had by your LCA's rubbing occasionally?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Re: How much damage can dragging LCA's really cause?
Just some minor chafing. Baby powder does wonders.
1986 Chevy 3/4 Ton 4X4 ![]() |
Cheyenne Super
It's the headers I worry about. Are yours stock or tube?
Baby powder lol ![]() |
6.0 powered square
do you mean rubbing the inner rim, or the ground
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
I'll try it but I'm not sure if its going to work ha
They are long tube right not but I'll have that fixed here soon enough, so it wont be a problem I mean rubbing on the ground
#6 | |
6.0 powered square
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 04-10-2009 at 03:18 AM. |
6.0 powered square
Buddie of mine hit a bad pot hole and it tore the lca of the truck
Happy to be here
![]() Join Date: Mar 2000
Get a visual of this, ok. Dragging along on asphalt wont do much damage.
Now imagine the stars are in alignment and you happen to dip at the same time you are crossing over a manhole cover. You know the ones that aren't "quite" flush with the road surface. I'll let you do the math... ![]()
#9 | |
Anything that hangs below the scrub-line is dangerous.....ever have a flat tire?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
I wish I had pics of when my hondas lca came off. It was nasty. trashed a fender and alot of other stuff. The only thing that sorta held it together was the axle.
82 Chevy SWB "OrangeAnimal" Lot of Goodies! Sold 93 GMC 1500 "Angry Red" 383 TBI Powered Fun! 300hp/410ft.lbs. 09 Yaris wife's daily. |
the pollock
scrub line?????
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
Workaholic
Here's an explanation I found online. . . Scrub Line Imagine your car-any car-sitting on the street without any tires. The wheels are still there, just without the rubber. Is anything touching the ground? Suspension parts, any brackets, exhaust system, fuel tank, transmission, or motor even? If so, they are below what is called the scrub line, and while you may not worry too much if those massive 6-inch lowering blocks meant the nuts on the U-bolts are now halfway down the sidewall of your rear tire, you'll be in for a nasty surprise if you get a flat on that tire at speed. Those U-bolts will make a nice gouge in the blacktop, and you'll be fighting to stay in control of the car ... if you're lucky. You'll more likely be in the ditch or facing oncoming traffic. Tall tires don't help either, but ensure no part of your undercarriage hangs down below an imaginary line drawn between the bottom of all four rims. In fact, an inch of clearance would be a good idea.
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
#13 |
the pollock
holy crap finally a "real reason" for having big rims he he he
