Old 12-23-2002, 01:13 AM   #1
70Chevy4x4Nut
Converting a chevy non A/C cab to a factory A/C type
I have a 1970 4x4 chevy Pickup with a factory A/C cab. It is rusted on the top lip of the windshield and has worked it's way to the inside. I worry about always having to repair this type of rust (not super bad but not sure how bad it is in the pillars that might start again later). I have an opportunity to get a better cab that is rust free but is non A/C. Can I install my dash and all components to make it a factory A/C type? Are there any major holes that need to be made through the firewall? Has anyone ever done that? And what would be the hardest part? I plan on doing a major restore so I will be gutting this truck anyway. Any information would be appreciated.
(This question not related to A/C swapout but I have to consider it since I'm swapping cabs.
Would I have to do anything about the hump area? I have the tall hump (with a cover) and this one may have the shorter hump. Did they come with a cover where it would be an easy swap or would the hump need to be cut out?
70Chevy4x4Nut is offline   Reply With Quote
Old 12-23-2002, 01:22 AM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Welcome to the board 70Chevynut4X4 ....I see you found the place...I just hope these guys can help you out with the rest of it.
Old 12-23-2002, 03:14 AM   #3
bigvinnie
bigvinnie's Avatar
if you're planning to put a factory a/c system in the new cab, you can remove the entire donor dash and install in the new cab.... if you're going with an aftermarket a/c unit, it would be much easier to cut new holes in the existing dash... I added Vintage Air to a non-a/c cab, which included templates for cutting the center and side vent holes.... center vent is same as factory, side vents are smaller and more flush with the dash...
'72 short step, 350, 700R4, tilt, ps, pdb, a/c, lowered coils, etc., other work in progress... San Diego, CA
72 Stepside Project
bigvinnie is offline   Reply With Quote
Old 12-23-2002, 09:04 AM   #4
MOTHERTRUCKERS
You can cut your dash face out at the slots under the dashpad to change to ac dash face. The high hump can be installed in a low hump cab also by cutting the high hump out about an inch around the outside edge and using it as a template to cut the low hump out. I use cutoff wheels and a sawzall to cut them out and a wire welder to stitch them back together.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 12-23-2002, 10:15 AM   #5
My72Cheyenne
"Work in Progress"
My72Cheyenne's Avatar
Wait a minute. There is more to a factory air cab then the vents in the dash. If you notice, there are 2 holes behind the A/C unit on the firewall, as apposed to one for non A/C cabs. No amount of cutting will solve this problem. Has to do with the condenser unit. I believe you must have a factory A/C cab to install factory A/C. My Cheyenne has factory A/C and my dad's doesn't. We made the comparison a few months ago. Good luck.
72 Cheyenne 4x4, 350, th350, np205, factory air, tach, headliner, tilt
My72Cheyenne is offline   Reply With Quote
Old 12-23-2002, 11:11 AM   #6
snow man
Cool firewall
can somebody post a pic. of the air fire wall compared to a non air cab. thanks snow man
snow man is offline   Reply With Quote
Old 12-23-2002, 11:17 AM   #7
72MARIO
72MARIO's Avatar
check out Johns site he has some super cool infogo here
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 12-23-2002, 11:19 AM   #8
50272
Non a/c cabs firewalls can be converted to a/c. You can make a template of the a/c firewall and use it to cut the non a/c cab firewall.Then cut the section out of the a/c firewall and weld it in the non a/c cab.I did it- it is a lot of trouble but was my only option at the time. Also helps to have a good welder.
50272 is offline   Reply With Quote
Old 12-23-2002, 11:21 AM   #9
67/72junkie
AC
It is not hard to convert a non ac cab over to ac . The fire wall where the ac box is the problem.This needs to be replaced with a donor from an ac cab.It is fairly simple.Drill out spot welds around perimiter and you will have one cut to make about 3 inches long.Remove the other one the same way and swap.It can be finished so that no one will know its been converted unless you tell them.The holes for the vents can be traced and cut out of the dash.Disassemble the ac cab first and by the time you are finished you will notice the other small things when you bolt it back in .This also lets you place the ac firewall section over the non ac section to match the cut I mentioned.It is very easy to see exactly what all the differances are on to bare firewalls.Hope this helps.
67/72junkie is offline   Reply With Quote
Old 12-23-2002, 05:13 PM   #10
TxGary
TxGary's Avatar
Non A/C firewall.
71 C-10 SWB
1969 C-30 Custom Camper Motorhome Restoration in progress.
2020 Chevy 2500 Crew 4x4 LTZ Diesel
2024 Chevy Tahoe Z71 4X4
2015 Diamond C 22' HD car hauler
Bowie, Texas 76230
TxGary is offline   Reply With Quote
Old 12-23-2002, 05:16 PM   #11
TxGary
TxGary's Avatar
Non A/C firewall converted to A/C.
71 C-10 SWB
Bowie, Texas 76230
Old 12-23-2002, 05:26 PM   #12
snow man
Cool air cab
thanks gary i can see the what i need to get now. snow man
Old 12-23-2002, 05:39 PM   #13
hwedding56
hwedding56's Avatar
Dont forget to save the glove box from your donor. They are differant also
67-CST Factory PS PB AIR Buckets SWB FLEET 350-700r4
67-SWB Step Plain Jane
350-3 on the tree
68 1-1/2 ton Dump 12' rock Bed soon to have fast68's 292 installed
72 GMC 3/4 ton Crew Cab 402 BBL
400 tranny ( ok I bought it from Crews) Its one ugly long WB long bed 4 door truck!!!!!!!!!
hwedding56 is offline   Reply With Quote
Old 12-25-2002, 07:28 PM   #14
70Chevy4x4Nut
Thumbs up Thanks everyone for the information
Thanks for all the replies. I know where to go from here.
Thanks Again
Old 12-25-2002, 07:47 PM   #15
71k5
Welcome from PA!
71k5 is offline   Reply With Quote
Old 12-25-2002, 08:09 PM   #16
67/72junkie
That cut was slightly longer than I remember but it has been several years since I did this.That first cab looks like TxGary has the beginnigs of another one of his fine restorations.
Old 12-25-2002, 09:32 PM   #17
Low69CST
I cut my non a/c cab to make it an ac cab. I have all the stock style parts bolted up to it. Theres one bolt hole that needs to be welded up. I didn't figure that out til after my firewall was painted. It isn't hard to cut up the fire wall. If you want to see some pics just let me know.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
