Sunburst C10!!!
coil overs
i am thinking about putting coil overs on the rear of my 64 on the stock mounts that i am bracing with 16 gauge
would it work better than the stock coils it has a trailing arm suspension
Gage 1967 C10 Shortbed Stepside |
Sunburst C10!!!
Re: coil overs
what are you planning on using for the mounts im just using the stock ones
Sunburst C10!!!
Re: coil overs
when are you planning on doing it
Sunburst C10!!!
Re: coil overs
i wish i would have taken mine off the frame and filled in all the holes and boxed in the frame but the P.O. had already painted it and put new bushings under the cab
#5 | |
Re: coil overs
You really should look into this a lot more before you do this. The stock shock mounts were NOT designed to support the weight of the truck. You need to make a substantially stronger mount on both ends before it will work with any degree of safety/reliability. If a mount breaks while driving, the frame drops instantly to the bumpstop....what happens then? Tire rub? Exteme pull to one direction? Panic?....all of the above?
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
Sunburst C10!!!
Re: coil overs
im bracing the sides and the boltholes with 16 gauge plate
Old Heap Driver
Re: coil overs
_____________________________ Bryan '99 Silverado 1500, 4.3, 5-speed, reg cab, short bed '50 Chevy 2DR Hard Top, 350/350, M2 Front End, 3:08 gear, cruiser. '40 F**d Sedan, all Chevy power, Heidt's front end, TCI rear, nice driver. |
